Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th December 2006, 04:15 PM   #1
maxlorenz's Avatar
Default Quick question: parallel LM317
I run a multi TDA1543DAC. I have some HF noise. One of the possible sources that I want to discard is noise generated by the LM317 regulator running too hot or near/over its current limit.
Typical max I for TO-220 is 1.5A and limit is 1.8A.
I made a test regulator consisting of two units with its pins soldered in parallel and they keep the desired Vout with only the standard pair of R.
By this mean I want to make that each reg passes half the current and *possibly* works more quietly
Does anybody see any inconvenient to this approach?
Thanks in advance...
M
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink
Old 8th December 2006, 04:40 PM   #2
jackinnj's Avatar
it's just a little expensive to do it that way, but National Semi shows it in their product folder. (i have done this with their switching regulators --- just stacking one on top of the other.)
the amount of heat which can be dissipated in one of these regulators is a function of current times the differential between in put and output voltages.
Old 8th December 2006, 04:41 PM   #3
pinkmouse's Avatar
Would it be less noisy to use a meaty pass transistor?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th December 2006, 05:18 PM   #4
jackinnj's Avatar
it may be less noisy to have the two references operating -- but I haven't demonstrated this (and don't want to spend the time doing so).
Old 8th December 2006, 07:17 PM   #5
maxlorenz's Avatar
Thanks guys
I just wanted to be sure...
Oh! I missed that, sorry...
A good friend designed a circuit for this application but I haven't got all the parts needed
Anyway, I think I'll learn in the attempt
Best regards,
M
Old 8th December 2006, 08:01 PM   #6
jcx is offline jcx  United States
Sorry guys but you're all wrong
you may get lucky but you shouldn't literally parallel pins of a pair of feedback amplifiers -which is what the Vregs are
if the internal Vrefs, loop gains don't match very exactly then the low impedance outputs will not share the load equally, with the Vregs only being able to source current at least it may not blow up like opamp or chip amp outputs tied together without sharing/limiting series R, but likely one reg is supplying 90% of the current
pinkmouse' approach is fine if you have a spare ~ 1 Volt of headroom
Old 8th December 2006, 08:14 PM   #7
maxlorenz's Avatar
Mmmhh...thanks, I'll study it again.
Old 11th December 2006, 03:22 AM   #8
maxlorenz's Avatar
Hi Jcx,
You were right, of course.
I did the test. I can't measure current but the new paralelled reg is hotter than the ancient: 58ºC v/s 38ºC, meaning, I guess that one is doing all the task.
The HF noise is still there, so it is comming from other place.
I would say music is clearer ...but I'm not sure.
As I can't source parts easilly, would it be worthy if I reproduce the regulator circuit, to end with two paralelled paths?
Will they pass a comparable current?
Thanks for your help,
M
Old 11th December 2006, 03:48 AM   #9
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
You could try this circuit http://www.diyaudio.com/forums/showt...45#post1005645 if you want better performance and have a beefy NPN or N channel FET handy.
Brian
Old 11th December 2006, 04:17 AM   #10
maxlorenz's Avatar
Thanks BWRX,
I'll check my box...
lm317 CCS question wicked1 Tubes / Valves 14 25th April 2008 10:19 PM
LM317 and LM337 Regulators in parallel jlm Solid State 7 7th January 2006 09:08 PM
LM317 and LM337 Regulators in parallel jlm Power Supplies 2 7th January 2006 09:50 AM
LM317 with a parallel transistor for current? Progg70 Power Supplies 2 31st August 2005 06:01 PM
Page generated in 0.09951 seconds (80.00% PHP - 20.00% MySQL) with 10 queries
