Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th December 2006, 12:55 PM   #11
jackinnj's Avatar
Originally posted by jcx
Sorry guys but you're all wrong
you may get lucky but you shouldn't literally parallel pins of a pair of feedback amplifiers -which is what the Vregs are
if the internal Vrefs, loop gains don't match very exactly then the low impedance outputs will not share the load equally, with the Vregs only being able to source current at least it may not blow up like opamp or chip amp outputs tied together without sharing/limiting series R, but likely one reg is supplying 90% of the current
pinkmouse' approach is fine if you have a spare ~ 1 Volt of headroom
yupp, National shows 0.22R load balancing resistors -- in using the SimpleSwitchers from National, all you have to do is stack the devices. I don't think that these buck/boost regulators get a lot of use in quality audio circuits.
lm317 CCS question wicked1 Tubes / Valves 14 25th April 2008 09:19 PM
LM317 and LM337 Regulators in parallel jlm Solid State 7 7th January 2006 08:08 PM
LM317 and LM337 Regulators in parallel jlm Power Supplies 2 7th January 2006 08:50 AM
LM317 with a parallel transistor for current? Progg70 Power Supplies 2 31st August 2005 05:01 PM
Page generated in 0.05518 seconds (66.38% PHP - 33.62% MySQL) with 10 queries
