| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm looking for software to input a schematic, and perform a board layout/auto trace route... but i want something that's quick and easy!
Why? Because I etch my own boards, i will never source them out, and I just use whatever parts I have laying around. I tried a few others, and they work, but I'm sick of spending an hour to layout a dozen parts. I don't want to draw it by hand either, i like arranging the parts via computer. I want to click on capacitor and just have two holes on the board... i don't want to sort through a thousand different libraries of suppliers. anyone got a suggestion? |
#2 | |
http://www.expresspcb.com/regards |
#3 |
yep, express pcb works well. only bummer is if for some reason you need to put copper on top in which case need to mirror print, recall express pcb would not give you that.
i use sprint layout, but not free, 39 bucks.... has nice tiling feature for printing out multiples of your home ethes. even funnier, my black toner was running low and i could select copper color to print in some funky cyan to hit that toner cartridge (color laser). also hated made a layout, but couldn't get fabbed since no gerber export - although you say doesn't matter for yourself since home etch only. |
#4 |
I get great results with Sprint Layout from Abacom in Germany.
It's very easy to use, supports copper and silkscreen layers on both sides and it's real easy to whip up new parts that are not already in the libraries. http://www.abacom-online.de/uk/html/sprint-layout.html It's cheaper than Eagle if you want to make boards larger than the limitaions of Eagle allow. Did I mention it's easier to use?
pw |
#5 |
A powerful "free"/ open source program:
http://kicad.sourceforge.net/en/index.shtml KiCad consists from project manager and four main programs: * kicad - project manager. * eeschema - schematic editor. * pcbnew - pcb editor. * gerbview - Gerber (photoplotter documents) viewer. * cvpcb - footprint selector for components used in the circuit design. Almost no limitations for size and layers. A bit of learning curve. Libraries are OK, and can be custom made for your own parts. HTH
Two people can keep a secret if one of them is dead. |
#6 |
elementx, did you buy out mayfield radio shack's etchant?! know you work near where i work, went there to pick up a bottle for the weekend project and they said someone came and bought it all!
#7 |
You know, it really is cheaper to make your own etchant using Muriatic Acid from the home DIY stores and Hydrogen Peroxide from the Drug Store.
It might cost $5 per gallon, versus the $5 for 16 oz you pay at radio shack.
pw |
#8 | |
Did it Himself
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#9 | |
I've just looked at that. There doesn't seem to be any link between the schematic program and the pcb layout. At least it is not mentioned If true, that is a BIG weakness and source of errors creeping in, as well as a duplication of data entry. |
#10 |
I never said it was an EDA suite... if you want that, go with the limitations of Eagle or buy something like AUTOTRAX EDA from KOV
The original poster was just making ONCE-OFF layouts, as I am myself. I personally can design a PCB with Sprint Layout from an existing Schematic I snag from from the WEB (or hand draw) with little effort or mistakes. I don't need to spend time drawing the schematic unless I want to. Then I just use SPLAN from the same folks. The SPRINT LAYOUT tool does what the original poster wanted... Sprint is designed to be easy and is more geared to the hobbyist, which most of us seem to be. The issue with the error "Board and Schematic are not consistent!" in EAGLE is not something a DIY'r like me is always wanting to spend time on. To each his own... I like the simple solution sometimes. The DEMO versions from ABACOM.DE should show you how easy they are. If that's what you like... great.
pw |
| Layout software | mashaffer | Tubes / Valves | 2 | 26th February 2008 07:03 PM |
| PCB layout software | rtarbell | Parts | 1 | 10th January 2006 10:42 PM |
| PCB Layout software | thomasfw | Everything Else | 5 | 21st April 2005 06:02 PM |
| PCB Layout Software | Apogee | Everything Else | 33 | 17th July 2002 08:09 PM |
| Page generated in 0.10906 seconds (83.75% PHP - 16.25% MySQL) with 10 queries |
