Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th December 2006, 05:50 AM   #1
Nixie is offline Nixie  Canada
Banned
Default Serrated fans
I read that fans with serrated blades are quieter, and have seen some commercial models. However, I've not seen any small ones, so I'm wondering if I can just make cuts into the plastic blades of an existing fan, if I try to make them identical on each blade.
Old 4th December 2006, 05:06 PM   #2
I_Forgot's Avatar
I think it might be hard to do it accurately. If you unbalance the blade, it will vibrate while spinning and the vibration may make more noise or it will at least wear the bearings out faster.
It is probably better to just use a bigger, slower fan. 230VAC fans will run very quietly at 117VAC. Most 12V fans will start reliably and run quiet at 6-7V.
I_F
Bendy serrated wood sheets - how to use? andyjevans Multi-Way 5 26th September 2005 06:07 AM
amp fans sriegel Pass Labs 4 5th January 2002 11:10 PM
Page generated in 0.07375 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
