Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Why is mains frequency so low?
Old 29th November 2006, 03:53 AM   #1
Nixie is offline Nixie  Canada
Banned
Question Why is mains frequency so low?
Why was 50/60 Hz chosen? With higher frequencies, smaller transformers could be used.
Old 29th November 2006, 06:31 AM   #2
dnsey is offline dnsey  United Kingdom
It's a function of the generator design, as is the sine waveform.
In theory, you could have more poles, so as to produce a higher frequency, but there wouldn't be enough space to wind the wire (which is in reality heavy bar at these currents).
A further reason: when switching between generators, phase used to be adjusted manually (by observation on a dual-beam scope and adjusting generator speed). It's now done by computer, but used to be a skilled job even at LF. Imagine trying it at a higher frequency!
Old 29th November 2006, 07:01 AM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
It has also to do with distribution losses I'll guess. In Sweden (1800 km) you will get problems with wave lenghts if the frequency is higher. If you have a two pole motor you'll get 3000 or 3600 rpm which is good and not too fast.
The trains in Sweden has 15 Hz which later became 1/3 of 50 Hz (= 16.67Hz) and this was because we could make better transformers in 1925(?).
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 29th November 2006, 11:13 AM   #4
ralphs99 is offline ralphs99  Australia
ralphs99's Avatar
Hi Nixie,
An important consideration is the skin effect. AC currents tend to flow at the surface of a conductor rather than through the middle.
In copper at 60Hz the skin effect depth is only 8mm, so solid wires more than twice this thick are a waste of conductive material.
As frequency increases, the depth decreases making transmission line design more difficult.
Cheers, Ralph
Aeronet research pages
Acoustic, Electronic & Speaker Design
Why is mains frequency so low?Hide this!Advertise here!
Low Frequency Mains Noise ruffrecords Tubes / Valves 13 5th April 2017 11:16 AM
Mains frequency variation Circlotron Everything Else 11 3rd March 2008 10:49 AM
Change in frequency mains Raka Analog Line Level 49 17th January 2006 04:59 PM
Mains frequency stability Prune Parts 10 26th November 2004 05:09 PM
Copyright ©1999-2017 diyAudio
