Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th November 2006, 07:05 PM   #1
ptah is offline ptah  United States
Default PCB Hole Size
Folks,
Does anyone know of a hole size guide or reference for different circuit board components?
Old 26th November 2006, 09:45 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
I don't think there's a single reference for that, you have to look at individual component datasheets to find package information.
/U.
Old 27th November 2006, 01:24 PM   #3
Geek's Avatar
If there's one size drill bit you should have in your collection for PCB's, it's 1/32"
Old 27th November 2006, 03:36 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
Default Re: PCB Hole Size
Originally posted by ptah
Folks,
You check the datasheets for the part in mind, then add 0.2-0.3 mm if the board has plated holes.
Example: A resistor has normally 0.6 mm leads and 0.8-0.9 mm hole is suitable.
/Per-Anders (my first name) or P-A as my friends call me
Old 27th November 2006, 08:03 PM   #5
suvatn is offline suvatn  Thailand
Drill bit size for PCB manufacturing is starting from 0.1mm to 6.3mm, increment step by 0.1mm.
Normal single side PCB will be starting from 0.8mm.
Hole size usually will be component pin size + 0.2mm.
Old 28th November 2006, 04:01 AM   #6
BrianL is offline BrianL  United States
millimeters? All the PCBs I've ever done have hole sizes in fractions of inches! ;-)
Hole sizes are a combination of size needed to fit component leads and drill bits offered by the fabricator. For example, a number of the "prototype" PCB vendors (the kind you email your Gerbers to along with credit card number) have a limited selection of drill sizes in order to keep things standardized and keep their costs down (and hence keep down the cost to you). Thus, you may need to adjust the hole sizes on your PCB to fit their available sizes.
Other places, such as my current employer, seem happy to let you use any and every conceivable drill bit (in increments of 0.0005") all on the same PCB.
If you're doing your own PCB, make a set of reasonable choices. Avoid using a hole that is "just big enough" as it makes it hard to remove a component. You'll find that you need only a few sizes for the normal range of components.
bel
Old 28th November 2006, 05:27 AM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
When I was little the neighbours had a daughter, with 12 toes and 12 fingers... bet she'd learn to count and measure just fine in the USA... the rest of us use metric... I Know they tried it for 2 weeks in the US, but gave it up because it was too hard :P.
For 89.7% of the stuff you'll do, you need th 0.8mm bit.
Old 28th November 2006, 07:10 AM   #8
peranders's Avatar
Never heard of millimeters? 1 inch = 25.4 mm. My pcb fabricator can offer just about any hole size so I just have to pick the size I want. More than 10 different sizes is not a problem. If you make a doublesided board 0.9 mm is very suitable for 0.6-0.8 mm leads.
Old 28th November 2006, 07:35 AM   #9
djQUAN is online now djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
who's your fabricator BTW?
Old 29th November 2006, 07:39 AM   #10
Milimeter
http://www.crownhill.co.uk/level3.ph...aca0f3230738fc
In the past, yes in US, they use measuring in Inch unit but in Europe use in metric.
In Asia some mixed up from difference source, but now most of electronics semiconductor become small and smaller, measuring unit changing to Metric
I do not know exactly in US.
U.S. UNION TOOL, INC.
You can find out
In Germany, Kammer news reports that they finish to develop
0.03mm drill bit, you can see how small.
http://www.mpk-kemmer.de/KemmerTechn...02-05_engl.pdf
In Japan and Chaina, seem all of them supply drill bit in Metric unit.
Fostex 206e baffle hole size ljk11 Full Range 2 3rd January 2009 09:01 PM
Air Core inductor: Hole Size ! (waveforms shown) -_nando-_ Class D 67 14th January 2008 08:52 PM
bass matrix hole size....does it matter i4gotmyid Multi-Way 1 5th October 2007 03:27 PM
Help, Foxtex Fe207E FE206E hole size OzMikeH Full Range 5 6th April 2007 10:51 AM
FE127E hole size, Butt joints and using PVA glue with MDF bluegti Full Range 32 19th June 2006 12:53 PM
Page generated in 0.09256 seconds (88.49% PHP - 11.51% MySQL) with 10 queries
