| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I want to replace the output on my PlayStation as CD player. As it is now I use a high-pass network, cap and grounded resistor. I want to get rid of it and replace it with a 600:600Ohm line transformer.
When I replace the cap and resistor with the trafo I get lots of hiss and sound is really, really low. At first I thought there was a short or I had hooked up the trafos wrong since there was no sound at all. I had to crank up the volume to hear anything. It works when I hook up the transformer after the cap. But it's the cap I want to get rid of. The grounded resistor I have no problem with. I assume this is caused by DC. If that indeed is the case and the trafo assumedly gets saturated, can this be solved by using a different trafo? Then what should I look for in the trafo? Examples would be nice. I don't know if it matters. But I use the trafos unbalanced. |
| Line output as line input transformer? | bambadoo | Tubes / Valves | 7 | 22nd January 2008 06:44 AM |
| Questions about Line Arrays | Kensai | Multi-Way | 9 | 5th April 2006 08:27 PM |
| bipole transmission line fe167e problem / questions. | AudioGeek | Full Range | 15 | 21st March 2005 10:34 PM |
| Transmission Line Questions | Matttcattt | Multi-Way | 32 | 13th July 2003 06:20 PM |
| Transmission Line Questions | Solid Snake | Multi-Way | 16 | 24th June 2003 01:28 PM |
| Page generated in 0.06018 seconds (68.87% PHP - 31.13% MySQL) with 10 queries |
