Piezo Buzzers and Relays - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th November 2006, 08:08 AM   #1
Send a message via AIM to pinesolpirate
Default Piezo Buzzers and Relays
Hello all, few quick questions I'd appreciate some help on.
I would like to use the signal from using a piezo buzzer to trigger a solid state relay once the signal has reached an arbitrary level. I know very little about electronics, but I am trying to use the piezo's as drum triggers to close circuits on a keyboard controller and send those key notes to a computer.
I actually think my problem is also similar to a previous post in this forum:
Driving a latching relay
My reasons are best explained by reading the posts at the end that outline this project and it's failures, but in short I'm trying to create a very cheap electronic drum set, using some flexible software as the drum controller.
My alternative method is to use a micro controller, but I'll have to throw away a good deal of code, bumble my way through learning some new API's and just generally extend the project's required time.
I appreciate your time, and would also appreciate pointing me in the direction of some good books or resources to learn some basic electronics skills and some beginner projects as well. My Chu Moy amp ended in a mess from my lack of knowledge, and I'm hung up on this project for the same reasons.
Thanks again.
[Project posts in chronological order, oldest first]
http://www.velvetcache.org/2006/09/30/drumkit-v001/
http://www.velvetcache.org/2006/11/05/dk421-hardware/
http://www.velvetcache.org/2006/11/0...k421-hardware/
http://www.velvetcache.org/2006/11/09/the-first-pad/
http://www.velvetcache.org/2006/11/2...ture-of-dk421/
Reed Relays Vs Standard Relays steevo Solid State 9 21st September 2009 05:08 AM
DC offset and relays krusty75 Tubes / Valves 8 27th May 2008 03:31 AM
1 HP Relays jackinnj Swap Meet 0 15th November 2006 10:37 PM
Relays in amp hotscot Parts 80 31st January 2006 10:04 PM
state of the art relays Berki Parts 63 29th October 2004 02:33 AM
Copyright 1999-2017 diyAudio
