How do I mount big capacitors in a box? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th November 2001, 11:17 AM   #11
yeti is offline yeti  Germany
Default fixing caps
recently i solved a similar problem by using water-hose clamps.
Arne
Old 12th November 2001, 11:57 AM   #12
walker is offline walker  Australia
Send a message via ICQ to walker
On the topic of capacitor mounting, look out for PCB mounted caps that are glued to the board. The glue is usually yellowish and can darken with age. Over time the glue often becomes conductive and/or corrosive. I have had to replace many in both professional and domestic equipment, look out for it!
I have not found this problem with hot melt.
Remember when mounting large caps with high ripple currents, give them room to cool. For every 10 degrees C the caps life is halved.
Regards WALKER
Surface mount capacitors chris ma Parts 46 10th April 2013 11:42 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
wanted RCA female chassis mount...will trade hi-end capacitors KevinLee Swap Meet 0 14th December 2007 07:32 PM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS Swap Meet 1 22nd December 2006 06:18 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Copyright 1999-2017 diyAudio
