Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st November 2006, 07:00 AM   #1
Question How to do the etching
Please may someone give me information about the best size of drills to use when doing the etching and where possibly they can be found.
Old 21st November 2006, 09:56 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
Being in even darker Afrika than myself, you may have to order those online. most common low wattage resistors and most capacitors will need an 0.8mm drill and maybe it is handy to have a 1mm drill too for fatter legs.... you can always make the hole a little bigger when needed with the point of a knife...but you can't make too big holes smaller...
Old 21st November 2006, 10:34 AM   #3
djQUAN is online now djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I would recommend 0.8mm as smallest to use. any thinner and it will snap easily. 1mm would be good for large transistor legs or diodes.
Old 21st November 2006, 10:39 AM   #4
Nordic's Avatar
Sorry for posting again, I forgot to say, buy many more than you think you need, as they do break very easily.... cheap ones go blunt quickly, and expensive carbide types on the other hand are very brittle and can be damaged by just dropping them.
Old 21st November 2006, 10:41 AM   #5
with the carbide ones, even not using a drill press will break them! no kidding!
Old 21st November 2006, 11:41 PM   #6
dangus is offline dangus  Canada
#72, #68, then some larger ones to cover fat diode leads and such.
There's various dealers on eBay selling surplus or resharpened carbide bits (search for "micro carbide drill bits"). Sometimes bargain tool dealers will have assortments of those bits for good prices.
Regular high-speed-steel twist drills are OK for those occasional larger holes, but if you can't get the carbide bits, you can get by with HSS bits if you resharpen them frequently (a ceramic sharpening stone works). Machine-shop suppliers should have the "number drills" as they're called over here, or the metric equivalents.
Old 23rd November 2006, 08:31 PM   #7
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Here's a small tip for you guys, that I have been using for 35 years..
Take some round banana plugs, fit a selection of small drills, say 1, 1,2 1,5 and 2 mm, use ordinaray HSS drills, not carbide types..
and voilá - you have a selection of finger drills to fix holes that are too small.....
Old 23rd November 2006, 10:41 PM   #8
It's the 0.6 and 0.8mm that are usually the bigger problem.
regards Andrew T.
Old 23rd November 2006, 10:48 PM   #9
pinkmouse's Avatar
I find 0.8mm and 1.2mm cover 95% of my needs.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th November 2006, 07:18 AM   #10
Default ETCHING
Thanks to all those who gave me information I would be giving feed back after going through the project
Etching PCB:s Loial Parts 105 12th April 2012 03:22 AM
Problem with etching PCB!!! Please help! safetyman Parts 20 16th May 2006 05:35 PM
ENX bulb for PCB etching? Stocker Everything Else 0 6th May 2006 02:22 AM
254nm UV for etching? Stocker Everything Else 6 10th December 2005 02:11 AM
Etching PCB's - don't tell the wife pls! jackinnj Everything Else 13 8th October 2002 12:35 PM
Page generated in 0.10635 seconds (81.11% PHP - 18.89% MySQL) with 10 queries
