Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th November 2006, 03:41 AM   #1
neil_kaye's Avatar
Default mounting toroids
Is there any inherent problem in stacking toroids in a chassis? Toroids would be individually encapsualted with a single bolt running through the middle and anchored to the chassis. One end of the bolt would be isolated from the chassis to avoid any loop issues.
Old 15th November 2006, 04:18 AM   #2
I_Forgot's Avatar
They might get hot.
I_F
Old 15th November 2006, 05:51 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
Default Re: mounting toroids
No, as long as you mount them as you say.
/Per-Anders (my first name) or P-A as my friends call me
Old 15th November 2006, 06:59 AM   #4
stacking them will reduce the area exposed to cooling air and reduce radiation surface area.
This may become a cooling issue if used hard and/or in a warm case.
Their appears to be little or no electrical/magnetic interaction between stacked toroids.
regards Andrew T.
Old 15th November 2006, 08:02 AM   #5
peranders's Avatar
You are right Andrew, but toriods will hardly become hot in an audio amp at home unless the transformer is very small compared to the needed power.
Mounting hardware for potted toroids? fluckscapacitor Parts 5 23rd March 2009 04:41 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Toroids, mounting bolts, and shorted turns Saurav Parts 7 22nd March 2004 09:50 PM
Mounting toroids with little to no room for bolt ThingyNess Parts 24 27th February 2003 07:54 AM
Page generated in 0.07034 seconds (75.90% PHP - 24.10% MySQL) with 10 queries
