Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th November 2006, 01:31 PM   #1
traw is offline traw  United States
Default rly210 timer for softstart
Someone had given me one of these - wish to use to as softstart.
http://www.hobbytron.com/NTE/relay/pdf/RLY210.pdf
Looks like delayed turn on in series with load using terminals 1 and 3, thus need resistor like 50 ohm in parallel with 1-3 to leak some juice through for cap charging prior to delayed turn on. However, bothered with the 1A load mentioned which would shoot this down. or am i completely misunderstading this datasheet and device? perhaps alternate way to apply
Have alternate softstart built, but since had this one on hand and could be very tidy curious if useable. Modules a little pricey and cheaper to build softstart with simple relay.
Old 15th November 2006, 08:56 AM   #2
you read the 1Aac limit correctly.
For a medium to large toroid or large EI transformer soft start circuit you will need a lot more than this.
Note also, it is a solid state relay.
I don't think SS is suitable for supplying any decent transformer.
It may be OK with a PCB mounted transformer upto 36VA, but I would not trust it any higher.
regards Andrew T.
Old 18th November 2006, 10:18 AM   #3
frank1 is offline frank1  United Kingdom
But it would be ideal when used to energise a large power relay (with AC coil) as a slave.
FDJ
When to use softstart lordvader Power Supplies 27 29th November 2007 10:41 AM
softstart on bpa? Arx Chip Amps 3 17th July 2007 03:40 PM
Yet another softstart PCB harryeng Pass Labs 5 24th January 2006 08:25 PM
Page generated in 0.07542 seconds (71.79% PHP - 28.21% MySQL) with 10 queries
