Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
irf540 and irf9540 can these be tested with a dmm
Old 12th November 2006, 10:19 PM   #1
homertooties is offline homertooties  United Kingdom
homertooties's Avatar
Default irf540 and irf9540 can these be tested with a dmm
Hi everyone can these hexfets be tested with a dmm to see if they are bust or no .cheers
Old 13th November 2006, 12:50 AM   #2
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default IRF5XX TO BE TESTS
Homer:
First of all, I want to Know what parameter of the FET you wanted to test by a dmm, usually a dmm can only define out N channel or P channel, Gate junction failure, other than this, I don't think a dmm can do any further unless your dmm is a special made.
Give me more info. so that we can help!
BEST REGARDS
Old 13th November 2006, 02:52 AM   #3
clem_o is offline clem_o  Philippines
I think homertooties refers to 'gross functionality'...
Cheers!
Old 13th November 2006, 07:58 AM   #4
Default hexfets
Hi there thanks for replys i just wish to test them as in function,so i can determine whether i have to replace them or not as amp is getting a pain in the ****.............
Old 13th November 2006, 09:27 AM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Test drain-source and source-drain with an ohm meter. whilst gate and source are shorted. If short both ways then it's broken. The body drain diode will show some continuity source-drain depending on your meter, and setting to diode test will fully test this, but this is not necessary.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 13th November 2006, 10:14 AM   #6
Default hexfets
Hi there many thanks for reply i shall do that test
Old 13th November 2006, 10:28 AM   #7
Default hexfet test results look good
Hi all i have tested these hexfets and the readings are all done with diode test on my Di -log DL 293 Meter.
irf9540 (1) Gto S Shorted - lead on g and s + lead on D
reading 752 ohms reversed no reading
irf540 (2) G to S Shorted + lead on g and s - lead on D
reading 516 ohms reversed no reading
The above two fets were getting very hot when in amp.
irf540 (3) G to S Shorted + lead on g and s - lead on D
reading 518 ohms reversed no reading
irf9540 (4) G to S Shorted - lead on G and s - lead on D
reading 827 ohms reversed no reading
i am guessing these fets are fine and the trouble is in the pre and driver stages............
Anyone agree please let me know what a great forum this is...
Old 13th November 2006, 10:33 AM   #8
Did it Himself
Yes a bad device would show very low resistance at least one way if not both.
Old 13th November 2006, 10:36 AM   #9
Default further testing
Many thanks Richie00boy i shall play further with the tough dog,i will update later
irf540 and irf9540 can these be tested with a dmmHide this!Advertise here!
Irf540/irf9540 Amplifiers Schematic Collection zox2003 Solid State 30 16th June 2012 03:02 PM
ampli mosfet irf 540 + irf9540 xcicc Solid State 24 20th March 2009 12:10 AM
IRF540/IRF9540 bias bogdan_borko Solid State 34 17th May 2008 12:35 AM
can irf540 +irf9540 be tested with dmm homertooties Solid State 2 13th November 2006 06:19 PM
substitute for IRF9540/IRF540 elementx Chip Amps 1 7th July 2006 05:09 PM
