| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Can someone with DH Labs silvermatrix ic's please undo one for me and look in the plug. I need to know what the shield looks like and where it is fixed. It is only connected at one end. I bought a pair off e-bay. They were assembled by someone, who apparently didn't do his homework and forgot the shield! at least that is what I surmise. The sound is wierd. This is a simple fix (I hope!) but I cannot for the life of me "see" what the shield is or where it is. I have already posted this on Audio Circlesbut so far no one has answered who has a pair. Thanks. All replies will be appreciated. Shep
#2 |
what kind of cable is used, two core unshielded two core shielded single core shielded? Which?
regards Andrew T. |
#3 |
I don't know! (big help) here's there site
http://www.silversonic.com/docs/products/AirMatrix.html |
#4 |
that literature is not much help. Back to my questions. Let's forget about the shield. How many cores in your cable?
regards Andrew T. |
#5 |
A white/insulated center-to-pin
A grey insulated multi-strand to barrel/ground? Various layers hidden out of sight. Not much help i realize. I think I'm wasting your time. Either I take the damn things apart to find out what's not visible or I leave it the way it is. |
#6 |
Perhaps a pic of an open end of the cable in question? It would help.
/ Anders |
#7 |
As an example, some cables have 'two' earth runs.
The cables I'm using are Canaere star quad (meant for balanced microphones) that I've terminated myself. (a few other cables use the same basic ideas). My cable has two black and two white insulated conductors plus a braided sheild. At one end; two white are signal 'hot' - centre pin. two black are signal 'cold' - plug casing - gnd. Same at other end except that the braided sheild is also connected to the plug casing. Hope this helps...... |
#8 |
sounds like you have a two core plus maybe shield. Check the cores are connected like for like at both ends. Check that the shield is connected at one end to the barrel (ground). Mark the RCA plug to indicate which end the shield is connected to. If the shield is not connected at BOTH ends then is is not acting as a shield.
regards Andrew T. |
#9 |
Shepperd, does it work as is?
Al The miracle is not to fly in the air, or to walk on the water; but to walk on the earth. Chinese Proverb |
#10 |
The cable works as it. This invisible drain/shield is supposed to be connected at only one end according to"them". If indeed there are only two cores then the grey one is not supposed to connected at one end, but that makes no sense does it?
Sorry I've tried to take a picture but it comes out a shiny blur and anway you couldn't see into the barrel. I really am not keen to undo this and start over again. Cable termination of this kind is totally stressful and if you get it just a tiny bit wrong, nothing fits. When I say it works, it doesn't work the way the manufacturer says. He's formal and I agree. Connected the "right" way, with the arrows pointing to the amp, the sound sucks. I think who ever terminated them realized he was out of his depth and said "f..it, who's to know",so he left the shield out of the equation. |
| Thread Tools | |
| Interconnects | planarboy | Everything Else | 0 | 30th June 2008 01:01 PM |
| Best Interconnects? | Eric_B_C | Everything Else | 7 | 2nd January 2007 04:39 AM |
| DIY Interconnects | RyanW | Solid State | 13 | 18th December 2006 11:58 AM |
| DIY Interconnects | ralph-bway | Everything Else | 2 | 20th October 2003 11:02 PM |
| Cat 5 interconnects | ddatta | Everything Else | 6 | 19th March 2001 02:42 PM |
| Page generated in 0.19196701 seconds (84.13% PHP - 15.87% MySQL) with 10 queries |
