Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th November 2006, 12:05 PM   #11
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Directional
It is common to leave shield disconnected at one end, with "balanced" type cable (2 separate conductors+shield).
Shield/braid is often a lousy conductor.
Wich end the shield should be connected...there seem to be 2 opinions on that too...so you better try them both ways.
And many cables do not have any shield at all...
Arne K
Ars longa, vita brevis
Old 13th November 2006, 06:09 PM   #12
your unbalanced interconnect MUST have the pin and the barrel connected at BOTH ends.
If there is a third conductor, the shield, then it can be connected at ONE end only.
The other two must be connected at both ends.
If you have only two conductors, i.e. two core and no shield or single core and shield , Then you must as I said at the top connect both conductors at both ends.
regards Andrew T.
Interconnects planarboy Everything Else 0 30th June 2008 01:01 PM
Best Interconnects? Eric_B_C Everything Else 7 2nd January 2007 04:39 AM
DIY Interconnects RyanW Solid State 13 18th December 2006 11:58 AM
DIY Interconnects ralph-bway Everything Else 2 20th October 2003 11:02 PM
Cat 5 interconnects ddatta Everything Else 6 19th March 2001 02:42 PM
Page generated in 0.06958 seconds (62.95% PHP - 37.05% MySQL) with 10 queries
