| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I want to use Mills non inductive wirewound resistors on a DAC and tube stage PCBs. The throughholes are spaced about 1/2" (12.5mm) but the resistor body is 0.625" (16mm). Can I bend the leads back underneath the resistor to fit through the holes, or is this a bad idea...and hence be looking for a smaller part?
Use of resistors are for I/V conversion and high frequency filter in signal path.
Cheers ~ Mike |
#2 |
Can you mount the resistor on its side and then bend the leads 90 degrees into their holes?
#3 |
Unfortunately No. The body of the resistor is about 5/8" while the holes are probably 1/2" apart. I would need to bend the leads greater than 90 degrees...hence the body of the resistor would not be sitting flush on the pcb. Is this OK or should I look for a smaller part?
Cheers ~ Mike |
#4 |
No problems in bending the leads more than 90 degrees to make your resistor fit
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#5 |
Thanks Jan, that's the feedback I was hoping to get!
Cheers ~ Mike |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| what type of noise does carbon film resistor make ? audio taper wireround?? | prorms | Solid State | 12 | 14th October 2007 01:55 PM |
| How do you make an audio potentiometer into a variable resistor? | Darren Nemeth | Parts | 1 | 10th February 2005 07:15 AM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Page generated in 0.06747 seconds (79.06% PHP - 20.94% MySQL) with 10 queries |
