| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
When I build a custom chassis for my amp (Stereo 70 mod'ed to Van Alstine Super 70i) I regretably retained the original Dynaco tube sockets. Recently, several "problem" socket terminals have surfaced, so now I'm just going to change all of them out.
Anyway, the original Dynaco amp used a couple of empty tube sockets for BIAS checking, so instead of mucking up the chassis I left the 2 wires dangling inside (taped up). While I'm in there, I want to mount something small on the chassis so that I can just stick a probe in there to check BIAS, but a couple of tube sockets just won't look good. What do you guys use, and can you recommend a site where I can purchase it/them? |
#2 |
Bump - because after searching, I really don't know what to search on!
#3 | |
Look for 'test jacks' at places like Digikey. There are small (in Europe 1mm dia) hole ones that take standard multi meter test probe points. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#4 |
Bingo! Thanks janneman.
#5 |
You might also try "tip" jacks (Allied, for example).
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Bias problem- 1 Socket shows extremely low bias! | otokomae | Tubes / Valves | 12 | 31st December 2008 10:01 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
| Page generated in 0.09000 seconds (76.90% PHP - 23.10% MySQL) with 10 queries |
