| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi , i am repairing an old amplifier which has a dc offset problem and i need to replace some transistors which are bc477 , i wondered if any body could suggest a common replacement for these (maplin and rs do not no longer stock them ) vc 80v , hfe 100+ , ic 0.1a , ft 150m thanks for any help camt
#2 |
hello
from my towers book bc 477 = bc556 2n5550 2n3963 bft69 |
#3 | |
If you need more (= 80V) you may try BC640, which is a good 80 VCE transistor which have all the data you give for BC477, and better From practical reasons, it may be best to replace BCxxx with another BCxxx. There is a good chance they have same PIN configuration. E B C.
lineup |
| Replacement amp for A-Bus? | Greg911 | Class D | 0 | 16th November 2008 02:33 PM |
| Another cap replacement: uF changes.. | cuibono | Tubes / Valves | 8 | 6th November 2007 08:06 PM |
| OP amp replacement | mieze245 | Chip Amps | 0 | 19th September 2004 06:46 PM |
| Replacement for 5R4 | Ralph | Tubes / Valves | 8 | 16th December 2003 10:02 AM |
| Page generated in 0.06827 seconds (70.47% PHP - 29.53% MySQL) with 10 queries |
