Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd November 2006, 03:22 PM   #1
Default how to model 125-0-125 in PSUD
This may be really dumb of me, but either way, I'll learn....
I am trying to model a full-wave bridge rectified PSU using the Hammond 269AX transformer. The specs are 125-0-125 at 100mA. I was recommended to use this ina PSU that would give around 340V at B+.
Now, when I try to model this in PSUDII, I am unsure how to enter to transformer's details. If I enter 125VAC at 100mA, I do not get 340V DC at B+. However, if I double the 125 to give 250VAC at 100mA, I do get around 340V at B+. The design says not to use the center tap.
So, should I add both sides of the transformer to give 250VAC in PSUDII?
Thanks,
Charlie
Old 3rd November 2006, 03:41 PM   #2
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
That's right!
If you don't use the center tap, you actually get a single transformer tap with the two tap voltages added together. The rectified voltage you get is 250V * SQRT(2) = 353.55, minus some regulation and rectifier losses gets you around 340VDC.
You're on the right track.
Bakmeel
More Power Igor! More Power!
Old 3rd November 2006, 03:47 PM   #3
Great.....that's what I thought, Phew!
Thanks,
Charlie
PSUD question SHiFTY Tubes / Valves 6 8th March 2008 11:11 PM
PSUD II help Bengali Tubes / Valves 10 15th September 2007 04:58 PM
PSUD Model Hack Valverine Tubes / Valves 6 20th February 2004 06:48 PM
Getting my feet wet with PSUD Saurav Tubes / Valves 22 26th April 2003 03:12 PM
Page generated in 0.07224 seconds (69.96% PHP - 30.04% MySQL) with 10 queries
