Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st October 2006, 08:40 PM   #1
Default Needed: 250 ohm : 50K Input Transformer HELP!
I've been searching for this part for some time with no luck.
I need a Microtran mic input transformer, 250 ohm : 50K, single threaded stud mounting type (5/16" iirc).
I'll consider other makes as long as the specs and connector are identical. I could probably use several of these!
Also, if anyone has any advice on where to look, please advise.
Thanks!!!
Jason
Old 9th November 2006, 12:42 PM   #2
Lord Winter's Avatar
Default Something similar ...
Amplimo TM3
- I say let the Lord be our shield!
- The only shield I see is the one coverin' yer eyes.
Old 9th November 2006, 04:32 PM   #3
Default Amplimo
Thanks very much!
It appears this is the just about the closest spec I'm going to get.
(Beyer Dynamic p/n TR/BV 351.015.006 is similar).
If nothing else turns up in the next few days I'll try the Amplimo part. Thanks again!
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
Input needed on tweeters skooter Car Audio 1 13th December 2008 03:09 PM
Input cap needed photo_marc Tubes / Valves 8 2nd January 2006 06:40 PM
New sub design... input needed elambert Subwoofers 6 17th August 2005 08:28 PM
Page generated in 0.06781 seconds (71.07% PHP - 28.93% MySQL) with 10 queries
