Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th October 2006, 02:08 PM   #1
bobcat is offline bobcat  United Kingdom
Default Power switcher circuit dilema NEED HELP!!
Please can anyone out there in intelligent land tell me why after building this circuit,(attached) that in the off state & with the slave socket unloaded there is still main potential across live & neutral? if you put a small load i,e a 15 watt lamp across L&n the main potential disappears is there a floor in the circuit or am i going to have to leave a lamp connected at all times?
Any assistance appreciated.
B/c
Old 29th October 2006, 03:09 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I think you got your answer in Note 2 (the very last bit of the text).
You can meassure the main across the L and n with a high resistance meter, but you will not ne able to draw any current (like your 15W lamp)
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 29th October 2006, 03:21 PM   #3
Thanks for the reply but there is another dilemma! the neon in the slave socket that is connected also stays on in a no load state indicating power at the socket, when lets say my dvd player is connected it switches in & out of standby although this could be due to the fact that the on switch is in the secondary side,
Is there any way to stop the neon lighting, or replace it with a mains wired led
B/c
Old 29th October 2006, 03:32 PM   #4
Jan Dupont's Avatar
Sorry but I don't know this circuit...
Maybe someone else can help you
Old 2nd November 2006, 03:50 AM   #5
There are two possible reasons
One path is the RC across the triac
The second is the dc resistance of the triac. This will be about 1Mega ohm.
Try measuring the triac resistance out of the circuit, using a DMM.
The triac will be false triggered by noise on mains and this circuit is a bad idea to connect to a DVD. A simle solution will be a mains rated relay on the master supply.
Try connecting a high value resistor across the socket.
Gajanan Phadte
Tuning dilema with new sub Brownee Subwoofers 7 20th January 2007 07:46 AM
Class A amp dilema hudnes Pass Labs 28 9th September 2005 02:48 PM
Horns of a dilema Arthur-itis Full Range 0 4th August 2005 07:29 AM
Power supply dilema Nick Walker Solid State 1 19th April 2004 05:56 AM
Grounding dilema Bricolo Chip Amps 8 25th October 2003 12:08 PM
Page generated in 0.07502 seconds (73.48% PHP - 26.52% MySQL) with 11 queries
