Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th October 2006, 02:46 PM   #1
jarthel is offline jarthel  Australia
Default tranformer's magnetic flux
in EI cores is the magnetic flux higher on the sides or front/back?
here's a photo of a transformer (actually a choke but you'll get the idea): http://img56.imageshack.us/my.php?im...titled1vb4.gif
trying to figure out the best placement ( at least I hope it would be the best) of the transformers.
thanks for the help
Old 26th October 2006, 04:24 PM   #2
aerius is offline aerius  Canada
Depends. I found an easy way to do a rough check using a small neodymium magnet. With the transformer powered up, hold the magnet between your fingers about 2-3 inches from the transformer and make a slow circle around it. In some places the magnet will vibrate more, in some places less. Where there's less vibration there's less magnetic flux getting leaked.
Toasted PW tranformer? whitelabrat Tubes / Valves 16 2nd January 2008 01:42 PM
Step down tranformer jkeny Everything Else 2 18th October 2005 12:14 AM
Tranformer question CPX Parts 3 7th February 2005 07:44 PM
Can someone explain this tranformer? dvdwmth Chip Amps 5 9th September 2004 08:03 AM
leaking magnetic flux theChris Tubes / Valves 1 20th November 2003 03:40 AM
Page generated in 0.06573 seconds (67.66% PHP - 32.34% MySQL) with 10 queries
