| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
here's the link: http://www.hammondmfg.com/collins.htm
I've read that chokes and power transformes must 90degrees to each other (I think this is meant for EI core only) and must some distance from each other. But I'm not sure if this rule is for any kind of transformer. I needed the hammond so that I can use low-impedance headphones on my headphone amp. thank you. |
#2 |
Hi Jarthel,
The short answer is that it will be OK to mount the transformers in any orientation with respect to one another. The longer answer is that there will be a small amount of orientation dependant coupling between the transformers as not all of the magnetic field will be contained within the core. But for the case of output transformers, a small amount of coupling will not degrade channel seperation to any significant degree. Cheers, Ralph |
| Need some help with transformers (impedance matching) | cuztom15 | Parts | 0 | 10th March 2009 03:19 AM |
| help with amp install - speaker level input? | honder | Car Audio | 6 | 28th August 2006 09:23 AM |
| Question about matching impedances and transformers. | JoeBob | Parts | 3 | 29th November 2004 12:49 AM |
| I want to install a new woofer driver into my old broken speaker. | S.C | Multi-Way | 18 | 25th September 2003 05:40 AM |
| What speaker specs for a free air install (aka car door)? and other suggestions | MITMechE | Multi-Way | 2 | 11th May 2002 09:52 PM |
| Page generated in 0.07505 seconds (72.68% PHP - 27.32% MySQL) with 10 queries |
