Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th October 2006, 10:53 PM   #1
Tenson is offline Tenson  United Kingdom
Default 3pin capacitors
A quick question, what is the point of 3-pin capacitors? Is it essentially two caps in one package to save space?
Cheers!
Old 24th October 2006, 11:19 PM   #2
pinkmouse's Avatar
Some three pin caps just have an extra NC pin for more secure fixing and to make sure they are not inserted on the PCB the wrong way round.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 25th October 2006, 12:27 AM   #3
You say 'some', what are the others?
The ones I have have the pins labelled '1', '2' and '-' which is ground.
Old 25th October 2006, 07:25 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
just take a 9V battery and see which of the pins will hold voltage between them after you remove it...
Old 26th October 2006, 03:42 AM   #5
Could they be X2Y caps? X2Ys have "four" terminals but two of them are/should always be grounded (connected together), so its like they really only have three.
BTW, X2Y caps are a new type of cap designed to have ultra low inductance so they work well for very high frequency duty caps.
Google for x2y if you're interested, there is plenty of info on them.
Old 28th October 2006, 01:11 AM   #6
It just crosed my mind, unless you are talking surface mount, they are probably NOT X2Y. . .
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
From 230V 3pin to 120V 2pin? jkeny Power Supplies 7 6th March 2008 05:32 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.08347 seconds (75.10% PHP - 24.90% MySQL) with 10 queries
