Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd October 2006, 05:56 PM   #1
Default How to calc Resistor Values to reduce Voltage?
B+ secondary reading is 257V. Using 6dj8 circuit, and this tube is rated .325 amp, and requires 200V...so I need to reduce 57V (257-200)
So Ohm's Law says V=IR or 57V / .325 = R = 175 Ohm.
And P = VI or 57V x .325 amp = 18.5 watts x 2 (to be safe) = 37 watt.
I must be doing this way wrong as another fella suggested a 25K ohm resistor rated at 2 watts.
Please set me straight.
Cheers ~ Mike
Old 23rd October 2006, 06:22 PM   #2
what plate current will your tube operate at?
Now calculate what resistor you need at the quiescent plate current.
Now what range of plate currents flow when the tube is amplifying a signal.
What happens to the plate voltage as the plate current varies.
Is this good for an audio amplifier?
regards Andrew T.
Old 23rd October 2006, 06:29 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Andrew is right. Your formula is correct, but it is not the RATED plate current that you need to plug in but the ACTUAL plate current in the circuit, of course. Makes sense, no? Same for the anode voltage. What is the ACTUAL voltage in your circuit? That determines (with the supply voltage) the number of volts you need to waste, and that gives you the R and the P.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 23rd October 2006, 06:37 PM   #4
The voltage reading is 257 volts. 200 volts is the spec for the 6dj8 output stage I assembled.
I'm a beginner. I can measure voltage and ohms. But I haven't measured current yet. I'll have to read up on how to do this with my multimeter.
Cheers ~ Mike
Old 24th October 2006, 05:31 AM   #5
jarthel is offline jarthel  Australia
to measure current, insert a 5W ceramic 10ohm resistor between B+ and plate. measure voltage. use ohm's law to compute for current.
Old 28th October 2006, 03:54 AM   #6
Default measuring voltage "across" a cap?
Thanks Jarthel. I'll pick up a resistor tomorrow and try.
When someone says "measure the voltage across the cap" that is soldered to a circuit board, and the leads are not accessible (except by turning the board upside down) does this mean that you can place the DVM leads: (a) on the solder joints of the cap's leads on the underside of the board or (b) just on the cap itself respecting the positive and neutral orientation of the cap?
Cheers ~ Mike
Old 31st October 2006, 12:58 AM   #7
Default Re: measuring voltage "across" a cap?
options a and b seems the same to me. where else would you measure a voltage on point that is connected directly to the leads of the caps. so just turn the pcb upside-down and measure the voltage on the solder joints.
as for polarity if it's an elcap and you get negative voltage, just remove and the negative symbol and you get the proper voltage.
Resistor values in feedback loop/voltage divider??? vynuhl.addict Solid State 29 13th February 2007 02:05 PM
Math to calc optimal voltage of tube dac to match amp input sensitivity? riotubes Tubes / Valves 7 9th November 2006 11:08 PM
Resistor Noises: How to reduce them SeanPool Solid State 7 1st August 2005 05:40 PM
Resistor values Stocker Chip Amps 3 4th May 2004 03:10 PM
Resistor values? randytsuch Chip Amps 2 11th July 2003 01:08 AM
Page generated in 0.08724 seconds (77.22% PHP - 22.78% MySQL) with 10 queries
