| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi guys, was in Singapore last week. Discovered, quite by accident, a revolutionary new device, a 'passive power' device. It is supposed to be put between the power amp and speaker and has a small tube in it. When I asked the sales man what it did, he named things like 'round out the sound', 'make it more clear', 'much better', etc.
What do you think? Note: there is NO power supply or other power input. And no, I don't have a circuit diagram. Come to think of it, the designer probably has neither ;-) Jan Didden
/Another new issue: Linear Audio Volume 3! |
#2 |
Did it Himself
Well done for getting a pic, I'm surprised they let you!
Interesting, merely wired in parallel, must make massive impact on the sound
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 | |
Me too! I put on my admiring face, and they were really beaming! Jan Didden
#5 | |
A joke??? For around $ 80 US?? But, there's more to come.... I give you the passive pre! Just 100 $ US! The fluffy (damping?) material under the tubes is a nice touch. Jan Didden
#6 |
Holy S...
This must be the mother of all c r a p However it's quite interesting to have a peak inside these "magic" boxes .... Well done Jan It makes one think that if someone assembled a commercial high end preamp or poweramp the same way, how many would they sell
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#7 |
Jan:
Got any ideas about which of the tube pins are connected? A part of the grid? to the [6.3 V.?] filiment heater? ... Consider: a few feet of speaker cable might act as an antenna to heat the filiment ever so slightly, driving a modest stream of electrons into the vacuum of tube and some kind of filtration / modest gain / other activity at work to modify or boost the audio signal ... (or not )Or there could be some kind advantage taken of the local voltage gradient, the minute power differential relative to the local ground potantial. (FYI: the local voltage gradient can be huge, on the order of several hundred volts per meter, but the current vanishingly small from almost unmeasurable to a few microAmps. [This is what causes trees to grow up instead of out = )
#8 |
Very interesting devices. What a bargain too!
However, they're not too much beyond the realm of many other devices/concepts I've seen on this forum. Theories such as: Burning-in op-amps Freezing pictures of items to make the items work/sound better (WTF?) Green ink on CDs Raising the value of feedback resistors to "mellow" out sound Super expensive interconnects Able to hear op-amp sockets Etc. Etc. Remember: "Those who can make you believe absurdities, can make you commit atrocities." Voltaire
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#9 |
That fluffy stuff in the "passive preamp" must be feathers from a newborn chicken. Should be plucked no more than 5 days after it left the egg, preferably by fullmoon, and blessed by a 35 year old virgin with six toes on her left foot.
Only that way you can get the real smoooth sound that's so rare to find. Everybody knows that |
#10 | |
| External passive crossovers... In front of the power amplifier? | luvdunhill | Multi-Way | 8 | 27th July 2007 12:58 AM |
| Passive Pre-Amp causes huge power loss? | Dominick22 | Tubes / Valves | 9 | 28th September 2006 10:34 AM |
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| passive notch filter, how much power do they take? | Puggie | Multi-Way | 4 | 3rd February 2006 01:19 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Page generated in 0.10057 seconds (81.93% PHP - 18.07% MySQL) with 11 queries |
