| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need a crystal controlled clock generator IC for generating 10MHz sq. o/p(5Vpp). Something like 8284A but only a clock generator in it(with quartz crystal input).
Someone please provide the part number of such ICs. Regds, XiTRON.. |
#2 |
Is'nt it easier to get those XO in 4 pin metal can.
#3 |
Hey, I had purchased 4 pin 10.000MHz XO from KDS. But it provides an insufficient 350mVpp at 3.3V rated Vcc supply.
If this isnt abnormal, then its o/p voltage is insufficient for feeding the ref i/p of a digital PLL. So any suggestions..? PS : For a digital PLL, i just now found DS8906 as a serving solution. Datasheet dn link : http://eshop.engineering.uiowa.edu/N...7/DS005775.pdf Regards, Prasanna Rao. |
#4 |
Crystal oscillators come in 2 types 5V or 3.3V Vcc.
The PLL you mentioned DS8906,datasheet is dated 1986.Is IC still available? |
#5 |
you are right.. DS8906 might not be readily availabel..
I think motorola MC145170 will do.. however i dunno how old is this.. could you please find out.. |
| How many 3886 chips required to drive these woofers? | rhythmdiy | Chip Amps | 18 | 8th October 2007 04:07 PM |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 07:18 PM |
| Audiocom clock vs. LC Audio clock | KevinLee | Digital Source | 22 | 26th July 2004 01:29 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 01:20 PM |
| Word Clock Generator | fmak | Digital Source | 1 | 5th July 2003 01:41 PM |
| Page generated in 0.07109 seconds (73.03% PHP - 26.97% MySQL) with 10 queries |
