I'd love to get any info you could provide!
I've been searching for information about doing the same thing for some time now, and what little I did have was just lost on an un-backed up hard drive.(dumb!, dumb!, Dumb! Me!!)
Any plans, Sites, or other information would be helpful!
I've had so little luck in finding any information on the requirements needed by a Plasma cutter supply.
It might be that, the power supply could be made form a modified existing supply.....I don't know..
Thanks!, I'm really looking forward to seeing where this goes.
Tall Shadow
Tall Shadow
Well I only have plans for the torch head. I bought them on eBay, and I don't think it would be fair to the seller if I gave them to others. At $7, it's not much to buy them.
A directly mains-rectified and filtered supply using a multi-gallon salt water resistor can be found at http://tech.groups.yahoo.com/group/plasmacutting/files/HomeBrewPlasma/
However, I'd prefer a more efficient switching supply.
Oh come on, surely someone here knows about switching power supplies. Where do I find a 15 kVA high frequency transformer?
What about multiples of smaller transformers, like say several of this one in series: http://www.surplussales.com/Transformers/SwitchingXmers.html (TP) 20T0175-A01
Nice link!
Why not buy there 2 for 69$ each?
• Input: 115 / 230v - 15 amps max. 50 / 60 / 400 Hz
• Output: 48.0v @ 15.6 amps, 5.1v @ 50 amps, 24.0v @ 10 amps / 2000 watts total
• Voltage adjustment: ± 10% minimum
• Line & load regulation: 0.2% + 5mV max
• Ripple: RMS 0.1% or 10mV
• Ripple: Pk-Pk 1% or 50mV
• Dynamic response: 25% load step, 2% or 100 mV (any output)
• Recovery time: To within 1% in 300µ sec
• Overvoltage protection: 2 to 5 V 122% to 134% of output voltage; 12 to 48 V 110% to 120%; recycle AC.
• Overload protection: 105% to 120% of rated current. Auxiliaries 105% - 140%
• Short circuit protection: Protected for continuous short circuit, recovery automatic
• Reverse voltage protection: 100% or rated output current
• Thermal protection: Each module thermally protected. Input module: Auto recovery. Output modules: Recycle AC
• Dimensions: 5" x 11-3/4" x 5"H
Nixie:
"Can I put them in series to get the voltage I need? "
Don´t know but normally the secondary is left floating.
"$138 for under 1.5 kW is steep"
That depends...I suppose to buy only the parts (plus the broken parts )will cost about the same!
"and where's the DIY in buying a complete unit."
And why You look to surplus parts?
You don´t consider to mix and press ferrites and so on....
Ok that can be a point, but in my view that is not a challenge in contrast eg to create a useful plasma speaker!
Heinz!
Heinz!
The main point of having a transformer in a plasma cutter supply is isolation from the mains, so that the + clamp connected to the work piece can be grounded, so that the operator is safe. Otherwise I could just directly rectify mains and have the workpiece live, so that I can kill myself.Originally posted by powerbecker
I don't think your estimate is correct for a switching supply, thoug it would be if I went for a linear one, due to the need for a large transformer.That depends...I suppose to buy only the parts (plus the broken parts )will cost about the same!
My linear plasma speaker supply is 1.8 kW, not 3 to 5, and winding the small gauge winding for the high voltage plasma was trivial compared to what wrestling with a heavy gauge for the low voltage 15+ amp on a transformer of twice the size would be.that is not a challenge in contrast eg to create a useful plasma speaker!
Thanks for the link, but, as they are a manufacturer and not a retailer, somehow I doubt they'll sell me in quantities less than a hundred.Originally posted by Ultima Thule
http://www.paytongroup.com/
Nixie:
When the sec side is floating you can connect it where you like!
"I don't think your estimate is correct for a switching supply, thoug it would be if I went for a linear one, due to the need for a large transformer."
After you get finished it you will know it exactly!
"My linear plasma speaker supply is 1.8 kW, not 3 to 5, and winding the small gauge winding for the high voltage plasma was trivial.."
The powersupply is only a part of it. There is much more to do also the amp I count with!
"...compared to what wrestling with a heavy gauge for the low voltage 15+ amp on a transformer of twice the size would be."
No worry you had to use a lot of thin wires...litz for high frequency 15A...
- Design & Build
- Parts
- Plasma cutter power supply
