| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#2 |
That proprietary connector looks like vintage Pioneer. Circa late 60's, to mid 70's.
I've seen them sold on e-bay occassionally... but they run about 9 bux a pop, plus shipping. Why not open up the case and wire up what-ever connectors you prefer? hope this helps, David
Writing is good exercize for the texticles! |
#3 |
Hate those things.
#4 |
My parents' Dual integrated receiver/phono has the same speaker connectors. They do suck.
![]() -A |
#5 |
They are "DIN speaker connectors" if you need to buy them.
FDJ |
#6 |
I have a DIN speaker plug in my hand and it is horrible. The spade is about 4mm wide and the pin is about 1.2mm diameter. The spade is at right angles to the pin and pin to spade gap is about 2.5mm. Your pic does not look like this.
regards Andrew T. |
#7 |
Enjoy good sound
/ Anders |
#8 |
Proud Union Member
Looks like a modified Cinch-Jones connector.
#9 | |
They are definitely no DIN plugs. Close to $20 for a pair seems a little bit much. I think that one large and one small male AMP FastOn-Connector per channel should do the job. The larger ones seem to be blue, the smaller ones red. (if they have an isolation collar at all.) They are often used in cars. If you have a file, 4 of larger ones should do. Maybe not pretty, but it should work. (Just tested that the blue one fits nicely into the wider jack, I don't have the small ones here.) regards, Gerhard |
#10 |
Thanks to all of you for your help.
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Can anyone ID this type of edge connector? | HankMcSpank | Parts | 2 | 26th May 2008 01:54 PM |
| Re : BL type & GR type of transistor for Aleph-Ono | Arion | Pass Labs | 4 | 29th January 2007 06:15 PM |
| ATX connector | MaXiZ | Everything Else | 15 | 3rd January 2006 08:02 AM |
| What type of connector for coaxial O/P | theoracle | Digital Source | 2 | 10th February 2005 05:03 PM |
| Page generated in 0.09640 seconds (77.02% PHP - 22.98% MySQL) with 11 queries |
