Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th December 2002, 03:09 PM   #1
Default help building tube mic preamp
Hi.
I´m building a tube mic preamp that is a copy of the Pultec MB1. I´m having some trouble with the parts. I don´t know what voltage should I use on the capacitors and if the resistors are 1/2, 1 or 2 watt. Things like that. I´m searching for a experienced professional audio electronics designer/tecnician to give me those answers. Any good soul that can help me with my project will get the full manual for this vintage unit, claimed to be the best tube mic preamp design ever. The design is simple, but efficient. I payed U$60 for this manual, so if anyone interested on this project that can help me just contact rafafredd@hotmail.com...
Old 19th December 2002, 05:15 PM   #2
Joel is offline Joel  United States
Joel's Avatar
RF,
Almost all the resistors in a tube project will be 1/2 watt, and just to be safe, all the capacitors should be rated at least 400V, and 600V is better if you can get them.
Power supply resistors, for a pre with low current demands, would be in the 1 watt range.
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Building a Preamp ray bronk Tubes / Valves 11 22nd June 2008 03:51 PM
Building bass tube preamp. (Stupid) questions? madisqbu Instruments and Amps 27 30th November 2007 03:14 AM
First time building a tube preamp reeeky2001 Tubes / Valves 10 5th August 2007 09:57 AM
Page generated in 0.06491 seconds (73.62% PHP - 26.38% MySQL) with 10 queries
