Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th October 2006, 09:27 PM   #1
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
Default strange op-amp circuit
I just listed through a complex 480 pages long book about op-amps, but I didnīt find this circuit.It is shown in few Fender amp schematics, itīs not connected in signal chain, but on the path to CA3080 in compressor circuit.
Can anyone tell me what is it good for, and why is it connected the way it is?
I have also plotted the in(green)/out(blue) curve.
Old 14th October 2006, 09:28 PM   #2
and the graph:
Old 14th October 2006, 09:48 PM   #3
FastEddy's Avatar
Unity gain, inverting Op-Amp circuit with + & - terminals reversed top to bottom from "common practice".
(Everything you wanted to know about Op-Amps but was 'fraid to ask = http://www.tinaja.com/ ... When he was a lad of 20, he began writing Op-Amp Cookbooks circa 1970 ... eventually becoming an engineer for National ... now quite independant and full of crazy ideas about "perfect" sign waves, etc. ... )
Old 14th October 2006, 09:51 PM   #4
I donīt understand, you want to say it has unity gain? No it doesnīt.
Old 14th October 2006, 09:57 PM   #5
FastEddy's Avatar
OK, so what is the gain? (I assumed that with 560 ohms on both the top and bottom, inverting and non-inverting feedback loops, the gain of The Amp would be unity ... granted there is resistance of 5.6K on both inputs, but The Amp is set to unity = 1 = gain. ... Overall circuit might produce something like a negative "gain" of -1.8 to -2.x or more (= -less).
Old 14th October 2006, 10:01 PM   #6
You see the graph, the ouput changes 24volts for cca 1volt input change, thatīs a "gain" of 24 (+/- somehting).
I donīt understand this circuit, but I think the ouput product highly depends on input offset voltage.
Old 14th October 2006, 10:11 PM   #7
The output doesnīt depend on offset voltage, nor offset current. Changing R2 changes the slope, other resistors just move the ouput "left/right".
Old 14th October 2006, 10:13 PM   #8
FastEddy's Avatar
Yes, yes ... yes, now I see what you mean.
This thing is set up like a Schmidt Trigger .. as soon as the input voltage crosses ~= +0.6 volts (input transistor threshold), it flips over to the positive rail voltage ... and vise versa. A voltage follower with high gain = Schmidt Trigger = a common "flip flop" circuit since the invention of TTL logic ala TRW (Dr. Ramo = the R in TRW).
(I am totally wrong about the circuit gain and the Op-Amp gain ... without the input resistors this would probably oscilate or latch to one rail or the other = gain >>= 10X.)
Old 14th October 2006, 10:15 PM   #9
pinkmouse's Avatar
Where in the circuit is it? What is it connected to? It looks to me that it is amplifying a lot and driving the output to the rail limits with a small input. Almost like some sort of square wave generator.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 14th October 2006, 10:16 PM   #10
FastEddy's Avatar
" ... It looks to me that it is amplifying a lot and driving the output to the rail limits with a small input. Almost like some sort of square wave generator. ..."
Exactly.
Strange bias circuit. WTF? Captn Dave Tubes / Valves 12 30th April 2009 04:34 PM
Strange circuit - heater hum opt feedback? m6tt Tubes / Valves 3 23rd April 2008 06:13 PM
Strange amplifier circuit - seeking information teemuk Solid State 6 18th March 2008 06:31 PM
Strange LTP cascoding circuit roender Solid State 3 11th June 2007 10:23 AM
Strange reverb circuit bembel Tubes / Valves 1 20th September 2006 04:55 PM
Page generated in 0.08626 seconds (87.32% PHP - 12.68% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
