Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
ferric chloride
ferric chloride
Old 19th December 2002, 01:52 PM   #11
On Hiatus
SY's Avatar
ferric chloride
Ferric chloride is the best etchant. If you have trouble locating it, try using something like sodium perchlorate or ammonium perchlorate. What you want is a strongly oxidizing Lewis acid.
Old 19th December 2002, 02:46 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
ferric chloride
Originally posted by sikkek
Peranders,
I don't think he has H2O2 bleach, but some chloric bleach. I don't know how that will react when mixed with HCl.....
hacknet, don't use any fluids if you aren't sure what it is!
Known working fluids:
Ferric chloride, whatch out for stains on clothes!!!
Ammonium persulfat (in Swedish). White powder, gets blue when used. Equally good as FeCl3 but it's easier to solve in warm water, no gases either. I have used it a lot. Watch out for stains on cotton, bleaches!! Can also make holes!!
Peroxide + HCl + 3 parts of water = dangeruos but really effective. Watch out for stains, holes in your clothes!!!
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 27 pcb's in interest.
Old 19th December 2002, 03:05 PM   #13
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Default Usable etchants
Ferric chloride exists in two versions,-- FeCl3 and FeCl2. Only FeCl3 is usable as an etchant...
The trick about FeCl3 as an etchant is that is is reusable until the "soup" is saturated with copperchloride....then the etching time increases dramatically and finally halts.. it also needs to be heated to 45-50 deg. to be usable without very long process time...
Other usable etchants are Sodium sulphate and ammonium sulphate, both can be reusable but needs the same heating as FeCl3. Should be available at electronic suppliers. Both gives a transparent solution, whereas Ferric chloride is a mess and stains everything..
All the above etchants needs air, either by being sprayed or foamed. Submersion only don't work....
An alternative etchant is 50% strength hydrochloric acid, 50% hydrogen peroxide, and water, mixed in 1 : 1 : 2.
This is a one time solution that must be mixed immediately prior to use, and then disposed of. Cannot be stored ready made. Mix accurately, or you have no process or ultra fast , which gives too much underetching of the edges.
The process develops chlorine gas, so use well ventilated only...
Good luck
Old 19th December 2002, 03:06 PM   #14
hacknet is offline hacknet  Singapore
i got Cl bleach... i guess i can use it to bleach my school shoes.... bleach iz kinda acidic rite... cant i get it to work?
Old 19th December 2002, 03:09 PM   #15
On Hiatus
SY's Avatar
ferric chloride
Small pedagogical point from a former chemistry teacher- FeCl2 is NOT ferric chloride.
The persulfates will work fine. IIRC, sodium persulfate is the fastest of the persulfate etchents.
Old 19th December 2002, 03:11 PM   #16
can i boil off the bleach to make it more concentrated? i got 7 liters... help me get rid of it guys!!
Old 19th December 2002, 03:12 PM   #17
i juz found a supplier dat sells fecl2... iz cheap but i need a licence from the ministry of environment before i can purchase the chemical!!! pcb etching is out of the window!!
Old 19th December 2002, 03:18 PM   #18
AuroraB's Avatar
I stand to be corrected.... ,
but FeCl2 does exist, but is still not usable as an etchant...
For the Sodium an ammonium stuff, -they are both -persulphates...of course...
The HCl, H2O2 and water mixture is actually quite fast. I have often used it in "hurry" situations and for non critical work, when my etching machines where out of duty, for some reason or the other....
Old 19th December 2002, 03:42 PM   #19
peranders's Avatar
ferric chloride
Don't we mean FeCl3?
Old 19th December 2002, 03:47 PM   #20
peranders's Avatar
ferric chloride
Forget it if you don't know what it is! If it is H2O2, no, you can't boil it!
ferric chlorideHide this!Advertise here!
Removing sharp perforation edges on stators with ferric chloride bigwill Planars & Exotics 33 15th July 2007 03:56 AM
Help: ferrous chloride/water ratio theAnonymous1 Everything Else 41 30th March 2007 09:50 AM
