| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have not used them before so...
is the side with the black ring the cathode? I have a feeling it is. But I do not want to blow it up as the value i'm using isn't available locally. thank you. |
#2 |
J,
That sounds right. You sound rather raw at this, so I will go slow. The band usually (99%) of the time is the K or Cathode. That on the print is the flat part of the diode. The Anode or A is the arrow head part. A simple check if the diode is any good. Let's assume it's a 12 volt ZD. Place it in series with a resistance of 5k ohms, then across the whole thing run some voltage across it. Measure across the diode body and you should see the voltage the diode conducts at. Later dude and good luck Jack Crow in Kuwait |
| Some noise measurements for LEDs and zener diodes | Christer | Parts | 127 | 25th November 2011 11:47 PM |
| 15V zener diodes | mantisory | Vendor's Bazaar | 0 | 16th November 2007 11:55 PM |
| Bride of ZEN zener diodes | ding | Pass Labs | 21 | 3rd June 2006 04:31 PM |
| computer amplifier zener diodes overheating? | DoomPixie | Chip Amps | 8 | 14th January 2006 01:23 PM |
| [Hybrid Amp] Questions about the use of zener diodes | Johnix | Solid State | 30 | 26th September 2004 08:00 AM |
| Page generated in 0.07047 seconds (68.22% PHP - 31.78% MySQL) with 10 queries |
