Let's Talk Capacitors Let's Talk Capacitors - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th October 2006, 01:20 AM   #1
speakerguy79 is offline speakerguy79  United States
Default Let's Talk Capacitors
OK, I am a COMPLETE newbie to *real* electronics. I'm an EE, but unfortunately all that means these days is that I can code and know some basics about electricity. I'm starting to play around with PCB design programs and would like to make some simple projects - active crossovers at first, progressing from there to digital stuff eventually. One of the things I find bewildering is the array of capacitor types.
So... the basic capacitor types:
Electrolytic - chemical caps. Based on some oxide layer forming on an anode IIRC, which requires a certain voltage to make form, which means they have a voltage offset. Useful for big values, DC work.
Film caps - polystyerene/propylene/whatever - I use them a lot in speakers. A generally good capacitor? I've only experience with radial leaded caps, no smt stuff. No idea what use they are in actual circuits other than loudspeaker XO's.
Ceramics - mainly used for bypass stuff? Are SMT ceramics/multi-layer ceramics as good as the disc kind? I think they are good at HF but small values for their size.
Tantalum - I have no idea what these are for
Mica - ditto
'Super' capacitors - the new ones that do 1000F at like 2.5V - I also have no idea what these are for, but they are expensive
Teflon - film cap I guess. Uses?
I know there are more, but I'm really just looking for someone to say "these are good for X" or "these are sucky for Y". Also, are SMT parts as good as ones with leads? I would like to do SMT stuff to keep board size down but not if audio quality would suffer.
Thanks!
Old 12th October 2006, 01:37 AM   #2
On Hiatus
SY's Avatar
Do not hesitate, run right out and buy Bob Pease's "Troubleshooting Analog Circuits," which has answers to most of your questions and much, much more. Great for adding the practical knowledge of a bench guy to the very theoretical orientation of modern academic EE.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th October 2006, 01:41 AM   #3
jarthel is offline jarthel  Australia
Default Re: Let's Talk Capacitors
polypropylene are used extensive in amplifier circuits. teflon has the same uses as well.
polypro is good. teflon even better. but some has said teflon might not be suitable in a particular circuit so this varies.
you also have paper-in-oil which are mainly used in tube circuits.
Old 12th October 2006, 01:42 AM   #4
also what are solid-state capacitors?
I found this on Gigabyte's website (the motherboard manufacturer) and searching the internet gave no useful sites.
thank you.
Let's Talk CapacitorsHide this!Advertise here!
Hello and could I talk to a mod? markdesmarais Introductions 2 10th March 2009 11:07 AM
Let's talk about the concerts we saw! Bricolo Music 62 19th April 2008 02:29 PM
Could someone here talk about the Theta Góˇ DAC? lanyuflying Digital Source 0 20th November 2007 01:24 AM
Enough about loudspeakers.... let's talk headphones Lisandro_P Everything Else 3 30th June 2002 11:42 AM
Copyright ©1999-2017 diyAudio
