| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm just getting into DIY, just finished building my first CMOY and being quite satisfied with it (despite not leaving any room for a pot haha). I've decided to take the obvious step up and build the Pimeta next using Tangent's great tutorial.
I took a look at the schematic, and while I don't understand most of it, I noticed that the power supply is very similar in design to the designs of other amps and DIY projects that I have browsed before. One thing specifically that I'm wondering about is the purpose behind the 'chain' of capacitors in parallel. Could someone explain this to me, so I can get a better understanding of what I'm building? Or if you know of any sites/threads which go over the basics of why amps and power supplies are built the way they are, that would be well appreciated also.link to schematic pdf |
#2 | |
Electrons are yellow and more is better!
1 Save space 2 You didn't have the right value. 3 Achieve good high frequency properties (if you also use smaller caps like 100 nF, 1 uF or so) The TL2426 is a voltage divider with some active parts inside with create in an articial way a low impedance voltage divider. It would have worked pretty good if you had taken 1 + 1 ohms but current consumption with have been undesirable high
/Per-Anders (my first name) or P-A as my friends call me |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| Cheap solid-state power supplies - would these work? | Spasticteapot | Planars & Exotics | 7 | 18th December 2006 12:27 AM |
| CRC Power Supplies | jleaman | Solid State | 1 | 12th March 2005 05:51 AM |
| 50V power supplies, qty=2 | kjunom | Swap Meet | 0 | 27th December 2004 09:32 PM |
| Regulated Power Supplies for Low Power Amps | PTL60 | Solid State | 18 | 6th February 2002 06:24 AM |
| Page generated in 0.05963 seconds (81.35% PHP - 18.65% MySQL) with 10 queries |
