Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th October 2006, 01:26 PM   #1
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Question Panelize Eagle PCB
Anybody know how to panelize a PCB made in Eagle.
I'm using the photo-transfer method, so I print the design to photo paper with a laser printer.
What I would like to do is to panelize the design, (copy it), so that I can make more than one PCB at once.
Any solutions to this?
Thanks.
Old 8th October 2006, 01:35 PM   #2
pinkmouse's Avatar
I use the CAM processor to output .eps files, then array them in Photoshop.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th October 2006, 02:20 PM   #3
Alcaid's Avatar
What settings do you use? I can't get an output with holes. All drill holes are filled black. And how do you assure the print out is according to scale?
Please explain your method a little more in detail.
edit: Got the hole-thing fixed.
Old 8th October 2006, 03:18 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
what I usually do is make the same layout many times in eagle.
Old 8th October 2006, 03:31 PM   #5
pinkmouse's Avatar
EPS is a vector format used by a lot of DTP programs.
I create a blank page the size of my printer paper, with margins set according to the printable area, (you only have to do this once then use it as a template), open the .eps file, select all and copy, then paste into the blank page. You can do this as many times as you want with as many layouts as you want. I then flatten the layers, (as each paste goes onto a separate layer), then print as normal, or save as a pdf. As long as your printer driver doesn't scale to fit, then each layout is dimensioned perfectly.
Al
Old 8th October 2006, 04:45 PM   #6
poobah is offline poobah  United States
poobah's Avatar
I don't know Eagle... but most programs allow to select whether or not you have holes in the copper pads. This option should be somewhere in the output/gerber generation window/cotrol panel.
Wish I could be of more help!
Old 8th October 2006, 04:48 PM   #7
in eagle, when you print directly from eagle, the result automatically has the holes in the layout. but when you export them first and open it in another program, the holes aren't there.
I haven't explored it that much so I don't know if there are settings for that.
Old 8th October 2006, 04:58 PM   #8
Nordic is offline Nordic  South Africa
Nordic's Avatar
I simply print from eagle to Microsoft Office document Image writer, (fancy way of saying printing to file), which saves it in Tiff format, with holes... at 300dpi.
Old 8th October 2006, 05:16 PM   #9
dsavitsk's Avatar
Default Re: Panelize Eagle PCB
I use this: http://claymore.engineer.gvsu.edu/~s...hon/gerbmerge/
It probably helps if you can read Python code, but it is pretty simple to use and works very well.
Old 8th October 2006, 06:23 PM   #10
Alcaid's Avatar
The method described by Pinkmouse works perfect!
Thanks everyone for the help
Eagle / .lbr tobias_svensk Parts 0 25th June 2004 06:11 AM
Eagle for Mac OS X JohnG Parts 6 8th May 2004 10:52 AM
eagle nickgreek Everything Else 0 6th November 2003 01:24 PM
Eagle in 3D nickgreek Everything Else 2 4th November 2003 12:21 PM
Need help with Eagle cad Shaun Perez Everything Else 1 21st August 2003 08:35 AM
Page generated in 0.10487 seconds (79.14% PHP - 20.86% MySQL) with 10 queries
