Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th October 2006, 02:15 PM   #1
jarthel is offline jarthel  Australia
Default what are the uses of zero ohm jumper resistors?
I was looking at the mouser catalog and I found this resistor. they are not exactly 0ohm but the catalog says it's 0.01ohm max.
what are the uses for them? why not just a piece of wire?
thanks for the replies.
Old 5th October 2006, 02:16 PM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
They were used as trace jumpers for single side boards.
With single side boards it's not always possible to avoid crossing traces.
Looks much better, easier for production.
Japanese amp boards often had long jumper wires.
The fancier ones had/have copper overhead strips for powersupply rails.
Looks like Sponge Bob has killed another thread.
Old 5th October 2006, 02:19 PM   #3
trace jumpers? like if a pcb is suppose to have a resistor but the design was changed and the resistor was removed. you place a zero ohm resistor in its place?
Old 5th October 2006, 02:19 PM   #4
djQUAN is online now djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I bought some just for the sake of having some.
that's the same reaction that everyone I showed it to.......
from what I know, it was made for automated machines where the machine was designed to handle resistors but not plain wires........not sure though. just a guess.........
Old 5th October 2006, 02:23 PM   #5
it's only 6 cents in mouser so it's not much but leads cut from resistors are just as good
it does look and sound cool though
Old 5th October 2006, 02:29 PM   #6
you can also use it to trick people saying that your PCB layout is so well designed that you never needed a jumper.
I actually got my 100pc pack for an equivalent of US$0.40 with the size of 1/8w resistors.
Old 5th October 2006, 03:04 PM   #7
Deceive the audience by adding a couple of color stripes
(great thing about digital cameras is that you can read every component and the schematic from a picture, this one is Mr Greg Ball's first OPA627 entry GB-amp lookalike from Germany )
Spot the jumpers :
Old 5th October 2006, 03:12 PM   #8
in raon? what shop? I'll asking my dad to buy me a desoldering iron next week so I might as well ask him to buy other stuff for me.
thank you.
Old 5th October 2006, 03:21 PM   #9
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
No. You had two traces that needed to cross on a single sided pcb, you would bridge one over the other with a zero ohm jumper.
Of course yopu can also use them for engineering changes, but that's another purpose.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 5th October 2006, 03:34 PM   #10
thank you.
yep. in deeco 2nd floor. look in the resistors section.
Jumper identification HELP JC Fardo Parts 0 6th May 2009 11:28 AM
Sonic Impact T-amp + RS auto jumper Decker Class D 3 1st May 2007 12:03 AM
Jumper on the bridge; calling 911 Nixie The Lounge 9 10th May 2006 01:27 PM
Biwire Jumper options?? greg7 Multi-Way 2 1st June 2003 09:53 AM
Page generated in 0.10080 seconds (82.17% PHP - 17.83% MySQL) with 11 queries
