Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
for a wood chassis, is glue enough?
Old 4th October 2006, 06:14 PM   #1
riotubes is offline riotubes  United States
Default for a wood chassis, is glue enough?
Building a DAC chassis out of 3/4" solid mahogany used for base and 4 sides. Top wil be 3/16" perforated aluminum. Dimensions are 12"x16"x5". Sides will be connected together using mitered edges. Aluminum top will be screwed down into top of sides.
Do I need anything other than glue (wood screws, etc.) to glue the 4 sides together, or the sides to the mahogany base?
Cheers ~ Mike
Old 4th October 2006, 06:23 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Biscuits would help align things during glue up, but other than that, if your joints are tight and you can clamp the assembly properly, you should be fine.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 4th October 2006, 06:58 PM   #3
Aengus is offline Aengus  Canada
Aengus's Avatar
Well, there may be a couple of issues.
First - as you likely know - wood movement can be an issue with cross-grain joints. You are probably OK with Honduras mahogony (Swietenia macrophylla) but some of the other "mahoganies" can move quite a bit; and 12" is quite wide.
Second, if you decide to make the ends with vertical grain to avoid the first problem, you are now gluing end-grain to end-grain, which is a challenge for most glues. A possible solution is to put in a couple of small butt-blocks at the joint (not a single full-length cross-grain block, of course). This will also help with aligning the joint while gluing up, since mitre-joints made slippery with glue are awkward without such things as biscuits, splines, or dowels.
Old 6th October 2006, 04:25 PM   #4
I second all those remarks.
End grain, slippery joints, biscuits help, additional internal glued strips are a low cost and very effective solution.
The glued strips can be square or triangular (half a square).
regards Andrew T.
for a wood chassis, is glue enough?Hide this!Advertise here!
Best way to glue wood without clamps? mr_push_pull Multi-Way 44 26th March 2015 12:44 AM
Undoing wood glue...advice needed :( Glowbug Full Range 10 23rd December 2007 03:11 PM
Hot glue on wood case for mounting? Dominick22 Chip Amps 6 14th June 2006 10:12 PM
Protect wood chassis from heat? leadbelly Everything Else 7 16th May 2003 06:39 PM
Calling Veneer Experts: Iron and Wood Glue Milzie Multi-Way 20 26th December 2002 01:09 PM
Copyright ©1999-2017 diyAudio
