riotubes said:Looking for a rotary spst switch to use as on/off for DAC. I want to affix a wood knob to the spindle, so I don't want one with an integral knob. 120VAC...around 5 amp. Suggestions on source?
Yes, I would like to know too. Only one's I have found are $30+
I also have some in stock...
www.apexjr.com/images/ROTARYPOWERSWITCH.jpg
There priced at .79ea
Steve @ Apex Jr.
Steve @ Apex Jr.
Hi Steve,
Do these stop once they click on, or keep turning?
Cheers!
Apex Jr said:I also have some in stock...
Steve @ Apex Jr.
Cheers!
Apex Jr said:These are a turn on-off . Click-click
Steve @ Apex Jr.
Thanks Steve.
I'm compiling an order list for you
These switches are nice:
http://www.allelectronics.com/cgi-bin/item/RS-142/search/2-POSITION_ROTARY_SWITCH,_DPDT_.html
5 watts at 125v.
DPDT - gives you some options! I guess if you wired the poles in parallel the rating would increase...
5 watts at 125v.
How do I wire this switch?
This 2 position rotary switch is a DPDT. Would be interested in using as an On/Off switch. How do I wire it? My experience is limited to SPST toggles.
I want to take the the hot pin of IEC inlet to a fuseholder, and from fuseholder to this Switch, and then from switch to positive lead of transformer. I want to take the neutral on IEC inlet direct to neutral lead of transformer, and IEC earth to chassis ground. Can I wire this DPDT in this arrangement and, if so, how? It has 6 pins. It's rated 5amps.
- Design & Build
- Parts
- USA source for rotary spst switch?
