Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
inrush current limiters
Old 16th December 2002, 07:59 PM   #1
colden is offline colden
Default inrush current limiters
Help, i'm looking for a keystone CL-60 thermistor. They have them at Digikey but with the minimum order rules and being a Canadian, I'd be looking at a bundle of $$$$. This device is to limit the start up current to my Leach superamp. If anyone knows where I can get one, please fill me in.
Cheers----
Old 16th December 2002, 08:03 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
inrush current limiters Send a message via AIM to Peter Daniel
I can send you CL-70. It has slightly higher impedance, but will work fine in this application, I used them.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th December 2002, 08:51 PM   #3
Default Cl 70
sounds great--email me please at colin_wood@telus.net
Old 17th October 2003, 12:19 AM   #4
markp is offline markp  United States
Has anyone every tried the NTC inrush current limiter devices? They are supposed to pass a certain amount of current and clamp down on higher currents. Sure would be an easy solution if it works.
If it sounds good... it is good!
Old 17th October 2003, 02:05 PM   #5
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Yup. I use them all the time, both on the primary and on the secondary side.
Frank
Old 17th October 2003, 02:10 PM   #6
Bryan is offline Bryan  United States
So then, if using the NTC on the primary side, what specs does one look at when choosing the specific device? Is it fair to assume that the resistance of such a device reaches a minimum when passing a specific amount of current?
For example, to use this device on a power tranny primary, which is rated as 150 mA, which device would be optimal, and why?
Thanks for entertaining the curiosity.
Bryan
Dont take life too seriously, you will never get out alive!
Old 17th October 2003, 05:56 PM   #7
sam9 is offline sam9  United States
sam9's Avatar
Default How does it work.
How do you use a thermistor such as the CL-xx to limit inrush??
I've seen other methods, but thi one is new to me. Is there a schematic to which I can be directed? Or which can be posted.
Old 17th October 2003, 06:07 PM   #8
Use the unit that will pass the maximum steady state current you are expecting to see. If you have a 6 amp transformer use the 6 amp unit. Just put it inline on the hot lead to the transformer input.
Old 17th October 2003, 08:30 PM   #9
fdegrove's Avatar
Bryan,
Sorry, what I use are PTCs not NTCs for overcurrent protection.
Epcos
Frank
Old 17th October 2003, 10:43 PM   #10
sam9's Avatar
Sound too simple.
What is steady state current with a power amp? I thinking of the dynamic demands of musical sources; a lot of the simple an amp is loafing and then there is a sudden demand that takes you to clipping. Do you select for max current assuming the caps are fully charged already? This seems like the right way. Any comments.
If these work they sure beat some elaborate schememes I've seen involving inductors, relay and whatnot.
inrush current limitersHide this!Advertise here!
Using Inrush Current Limiters hollowman Power Supplies 6 16th June 2012 10:27 PM
inrush current doktor Solid State 124 16th June 2012 10:22 PM
Tubelab SSE inrush current limiters. syyma Tubelab 9 28th August 2009 09:31 PM
Fuses, primary, rails, current limiters and channels? rgrayton Chip Amps 4 5th August 2005 05:15 PM
About Inrush Current JDeV Parts 0 2nd December 2002 07:40 AM
Copyright ©1999-2017 diyAudio
