Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th September 2006, 12:56 PM   #1
Nixie is offline Nixie  Canada
Banned
Question Shellac for transformers
1. Dewaxed shellac or not?
2. Cheap source of the flakes?
3. What ratio of flakes to methanol?
4. When vacuum impregnating, is it sufficient to have vacuum for only a few minutes? I'm using a water aspirator to create vacuum, and sustaining vacuum for more than a few minutes wastes way too much water (the aspirator is probably on the order of 1500 L/hr).
Old 26th September 2006, 10:36 AM   #2
is shellac the right chemical for a transformer?
regards Andrew T.
Old 26th September 2006, 11:41 AM   #3
Banned
I've seen it used before. Various varnishes seem to be used.
Old 15th October 2006, 08:03 AM   #4
Banned
Hmm, regular wood varnish seems to work fine. I even had mixed a uretane one with some other type, and diluted the stuff with acetone and methanol so it would flow in the smaller spaces better during the vacuum impregnation.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
What happened if spray shellac over lacquer andy2 Multi-Way 3 8th January 2007 04:43 AM
Will shellac be compatible with oil-based stain? andy2 Multi-Way 1 23rd September 2006 05:51 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
torn between shellac and lacquer andy2 Multi-Way 1 6th February 2006 05:57 PM
Page generated in 0.07535 seconds (70.99% PHP - 29.01% MySQL) with 10 queries
