Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd September 2006, 12:33 AM   #1
Relax is offline Relax  United States
Default HT Reciever Sub-Out for Pro Amp?
Will an HT reciever's sub output work to send the signal to a pro amp? Just curious if I need a line driver in there or something to step up the signal for the pro amp.
I plan on going from a KLH 5.1 reciever to a Behringer EP2500. I just want all the volumes to sound appropriate and was wondering if the KLH sub out is powerful enough. Basically will I have to crank the Behringer EP up just to be at the same level as the surrounds or not?
Thanks for your time!
~Jerick
P.S. I have a car audio Line driver I could easily use. If the line out on the KLH is weak, will that line driver work fine? If so- any ideas on the amount of amps a line driver would require if I were to find a ac-to-dc power supply?
Non HT reciever for Hi Fi. 901Fixer Solid State 0 24th June 2009 04:14 PM
help fix my reciever v1d9uy Digital Source 9 10th February 2006 01:47 AM
PC to AV/reciever johndory Digital Source 6 11th September 2004 05:20 PM
FM Reciever elnaz Analogue Source 1 18th April 2004 05:44 AM
Page generated in 0.06164 seconds (65.87% PHP - 34.13% MySQL) with 10 queries
