Mains filter QS
your consumption is about 200W as mentioned.
That needs a minimum of a 1A filter not 10A.
You could try to find a 2A filter to give some peak ability and prevent any risk of overheating.
Or split the load into lower consumption sources and higher consumption units and then fit two 1A filters.
BTW. check your dissipation in the ClassA amp, 80W input for 50W output does not add up.
