| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I found some lead-free solder solder in the Farnell catalog. It is made my Stannol by according to the datasheet, it is eutectic.
Composition is: 95.5% tin; 3.8% silver and .7% copper. The melting point is 217C degrees. Is there any disadvantage over lead solder? I know cardas is selling eutectic non-lead free and I somehow doubt that is inferior to the cardas eutectic solder with lead. here's the datasheet: http://au.farnell.com/jsp/endecaSear...sp?SKU=8400300 Thanks for the reply. |
#2 |
Stick with your first choice... the multicore... with lead and silver.
Used for high quality weapons the world over Lower temp Nice shiny joints No Cardas name High quality Made by solder experts... not fruitcake audio marketers No possibility of tin whiskers Thumb your nose at the stupid environmentalists that brought this garbage upon us Note: the medical industry, the military, aviation,/aerospace, back-up power, fixed telecom, and most "monitoring" equipment is exempt from lead free... for reasons of reliability. As the battle rages on, this will come to include power plant, building safety etc... lead-free will be limited (and should be) limited to the throw consumer trash. |
#3 |
your eutectic triple is a good electronics solder. Two things may go against it. Good/poor wetting of the surfaces. High temperature. Your iron temp might need to be raised by 30 to 40Cdeg to achieve quick joint completion. Good old fashioned 63/37 eutectic is better than many lead free. Although some with either some added copper and/or silver to save the bit or the plated pins have advantages.
regards Andrew T. |
| Good, inexpensive stripping/tinning solder pot. | Colescuttle | Parts | 0 | 25th September 2006 07:01 PM |
| is this a eutectic solder? | jarthel | Parts | 11 | 13th September 2006 08:15 PM |
| Is solder a good heat transfer medium? | leadbelly | Parts | 3 | 11th March 2004 03:33 AM |
| Good tweeter spk cable, long run | djcl.ear | Multi-Way | 3 | 3rd August 2003 06:53 AM |
| Page generated in 0.07169 seconds (71.14% PHP - 28.86% MySQL) with 10 queries |
