Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th September 2006, 02:32 PM   #1
Hans L is offline Hans L  Netherlands
Hans L's Avatar
Default How high is the input impedance of 'a' jfet transistor?
What kind of value can I presume a jfet transistor has for its input impedance? Tens of MOhms? GOhms? I've searched datasheets, but apparently the input impedance (which naturally is presumed 'very high' for jfet) isn't stated. Can it be determined from other specs in the datasheet? For instance via the Zero-Gate Voltage Drain Current? I'm currently testing (read: learning) with the 2n5459 (http://www.fairchildsemi.com/ds/2N/2N5459.pdf) and the BF245A (http://www.fairchildsemi.com/ds/BF%2FBF245A.pdf).
Any ideas how to easily measure it with reasonable accuracy given that it is 'very large'?
Hans.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. --- Douglas Adams
Old 14th September 2006, 02:48 PM   #2
Did it Himself
richie00boy's Avatar
Look at the gate-source and gate-drain capacitances and work out the impedance at the frequencies of interest.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 14th September 2006, 02:49 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: How high is the input impedance of 'a' jfet transistor?
Hans.
Basically it is so high that the leakage current across the leads over the package dominates any input current at DC. At AC, the input impedance is dominated by the input capacitance, which should be stated in the data sheet. Trying to measure a static input R is probably fruitless.
Jan Didden
/Another new issue: Linear Audio Volume 3!
High input impedance X circuit zelter Pass Labs 4 31st March 2009 10:06 PM
Low amp Impedance input and high dac output tulip Tubes / Valves 1 30th November 2007 08:24 PM
IGC with High input impedance! GregGC Chip Amps 0 30th April 2004 05:03 PM
P-JFET pass transistor borges Solid State 2 14th December 2003 07:01 AM
P3A question: high input impedance sobazz Solid State 1 14th July 2003 05:45 AM
Page generated in 0.08087 seconds (73.45% PHP - 26.55% MySQL) with 10 queries
