| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have made some modifications to my Behringer DCX crossover. I bypassed the output stage and went direct from the DAC chip to a pair of S&B TX102 attenuation transformers. Now, I did this with a DEQ before and a friend suggested I put an RC filter on the DAC's output (I presume to kill noise from the digital filter?). The component values I used in the filter were a 100R resistor in serial and a 4n7 cap in parallel across the two phases. Now it always worked fine from my DEQ into my Bryston amps, but I have now changed to using the DCX with these same mods into a different amp and I am getting some strange results... When I tried an LC Audio amp, it blew up! With my Alesis RA500 amps it works for a long time, then every now and again it just looses all the treble. A reboot of the amp brings it back. So.. I am thinking that there must be some high frequency noise on the line from my modded outputs which is upsetting both amps. Does that seem reasonable? Having looked up the formula for a passive line level filter, I find that (I think) I should have used a 100R resistor with a 47nf cap rather than a 4n7. Is that right? I just want to be sure I use the right values. So what value cap would I need for a low pass at, say, 40KHz? Am I right in thinking that the source and load impedance don't matter in this context? When I connect my oscilloscope to the outputs it is nice and clean when the DAC is off but when turned on, the line is all fuzzy. However, it does that even when not playing anything…. So I am not sure if that is HF noise it is showing or just my scope being funny because it is very old and flaky. Help for this noob much appreciated! |
#2 |
Okay, I think I got it figured out now, found the time constant formula which makes more sense.
| Low pass filter help | ifrythings | Subwoofers | 1 | 24th February 2006 09:45 AM |
| Low Pass filter | ThSpeakerDude88 | Everything Else | 4 | 8th November 2005 02:53 AM |
| low pass filter | crazyant | Car Audio | 3 | 15th September 2005 06:15 PM |
| D1 DAC from Pass 20 KHz filter? | promitheus | Digital Source | 2 | 15th September 2003 05:22 PM |
| Page generated in 0.08096 seconds (60.63% PHP - 39.37% MySQL) with 10 queries |
