Bob Pease on the New LM4562 - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th September 2006, 01:12 PM   #21
jackinnj's Avatar
$2.43/1k for SOIC -- about 1/2 the cost of AD797AR
Old 13th September 2006, 05:16 PM   #22
forr is offline forr  France
forr's Avatar
I'd like to see the internal schematics of the LM4562.
Old 13th September 2006, 07:42 PM   #23
wrenchone's Avatar
Given the rise in THD and IM at low levels (though it's still low), I wonder if the LM4562 would benefit from current source loading to force the output into Class A?
Old 13th September 2006, 07:56 PM   #24
wrenchone's Avatar
Just for perspective, the typical input bias current for the LM4562 is 5X less than the LT1115, and 20X less than the NE5532. In addition to reducing noise using MM cartridges (0.5-1H typical inductances!), there is more freedom choosing feedback components without having to worry so much about extra offset voltage.
Old 13th September 2006, 08:08 PM   #25
On Hiatus
SY's Avatar
Is it really distortion or is it noise?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th September 2006, 08:22 PM   #26
jan.didden's Avatar
If you look at the open loop gain vs frequency, it is ugly. Open loop bandwidth is 10Hz or so! Yes, that Herz, NOT kiloHerz!
So, the feedback in a closed loop config starts to loose effectiveness from 10Hz upwards, and that causes the rises of the hf THD once the harmonics come out of the noise.
The low THD of this thing is NOT due to its high ol bandwidth, but in some way they have made this thing extremely linear open loop.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 13th September 2006, 08:28 PM   #27
wrenchone's Avatar
Has anybody found a distributor for this part yet? I checked Digi-Key, Newark, Allied, Mouser, and Arrow. Either there is no hit for the LM4562, or in the case of Arrow, a hit but no stock. I tried Future, but their search just hangs up for 10-15 min without spitting out any results - a bad omen in any case.
Old 13th September 2006, 08:36 PM   #28
On Hiatus
SY's Avatar
Originally posted by janneman
...the feedback in a closed loop config starts to loose effectiveness from 10Hz upwards, and that causes the rises of the hf THD once the harmonics come out of the noise.
Well, looking at THD vs frequncy, it's pretty flat until you reach 10k, where it starts to rise. OTOH, the THD vs level shows the distortion rising monotonically with decreasing level. That's what suggested noise to me.
Old 13th September 2006, 08:41 PM   #29
wrenchone's Avatar
The LT1115 has similar open loop bandwidth characteristics to the LM4562 and similar behavior of IM and THD vs amplitude. Linear shows current source loading in their application circuit for an RIAA preamp. Makes me wonder... BTW, given the extremely high open loop gain of both parts, I wouldn't expect an open loop BW of much higher than 10Hz in any case.
Old 13th September 2006, 09:09 PM   #30
jan.didden's Avatar
Stuart, yes, I understood your post that you suggested that the rise of THD with freq was due to noise, which isn't the case.
Agree with the quoted post. The rise of THD above 10k is because at that freq (due to decreasing feedback effectiveness) the THD starts to rise above the noise. I would guess that if we could see below the noise the THD would steadily decrease with freq to 10Hz and flatten out from there downwards...
Jan Didden
Copyright 1999-2017 diyAudio
