| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Resistors often come in long stips...
When buying new ones, I take a pen and my multimeter and measure each one (without removing it from hte paper strips), then write down tha last digit from the multimeter display below each resistor... quick and painless.. Then in future when I need a matched set I just find two with the same number.... |
#2 |
Great simple little tip! Till now, I'd just find the best two matches, then have to do it all over again the next time!
PS Trying to find your thread on the voltage regulators. Finnaly gaot mine going.
Poor stereo mix? Switch to mono! Perfect. |
#3 |
then connect them in series (using terminal blocks) for super matching or into a measuring bridge. Better than 0.1% matching is easily achieved. Any thoughts on absolute accuracy? or how to get close?
regards Andrew T. |
#4 |
I think one way for a DIY to get more accurate measurements is to start with something like this:
http://focus.ti.com/docs/prod/folders/print/ref102.html ...and build from there. For resistors it would be best to have a connecterized resistor measured with an NIST traceable meter, then used as a reference for the type of voltage divider ckt described by andrew, or a bridge ckt. With the bridge, once zeroed, you could match very closely indeed, even with unknown bridge resistors. For low ohms, you need a kelvin ckt or a constant current source.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
help,
Kelvin ckt?
regards Andrew T. |
#6 | |
Good DVMs and PSUs (higher res) always have them. Here is my resistance box I made over 30 years ago, the lower values have 4 connections to eliminate lead resistance. |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| output resistor matching for LM4780 paralleled | Audiophilenoob | Chip Amps | 8 | 7th August 2005 10:03 AM |
| Matching Pmosfets with source resistor | AndrewT | Parts | 0 | 2nd April 2005 10:21 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| BJT matching | NickC | Solid State | 1 | 19th December 2001 07:41 AM |
| Page generated in 0.10112 seconds (77.69% PHP - 22.31% MySQL) with 11 queries |
