Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Closed Thread
Old 9th September 2006, 05:09 AM   #1
zBuff is offline zBuff  New Zealand
Default Is this a diode? picture attached
Our TV, gave up the ghost and stopped working, and some magic smoke came out of it. I opened it up and found that this component must have been the culprit, problem is I don't know what it is or what value it would be. It had a DL#### on the circuit board that would indicate it would a diode correct? I've just never seen one like that before. it has 010020 written down one side of it.
Worth replacing?
Old 9th September 2006, 05:17 AM   #2
rpapps is offline rpapps  Antarctica
Hi zBuff
DL usually signifies delay line although I'll admit I haven't seen one like that before. They usually don't release smoke.
What makes you think it's the culprit?
Cheers
Rob
Old 9th September 2006, 05:25 AM   #3
Thanks for the quick reply Rob.
So far it's the only component that I can see that has any signs of rupture or carbon deposits. Not too sure if the picture is clear enough to see it, but the metal is distorted (bent up) on the bottom left hand corner and the colouring seems a bit odd to me(not that I know what the usual colouring should be, due to my unfamiliarity with that type of component).
Old 9th September 2006, 05:46 AM   #4
unmibh is offline unmibh  Bosnia and Herzegovina
zBuff,
that's defenitely not a diode.
it's more like a variable inductor, inside that metal shell would be
a plastic bobbin with insulated copper wire and the ferrite in the middle is a screw and with every turn changes the inductance.
I you have a diagram this will be a symbol of a transformer with a diagonal arrow across it to indicate variable.
I hope this help.
unmibh
Old 9th September 2006, 05:47 AM   #5
No, I can't see the effects you mention in the image.
If it's a luminance delay line, as I suspect, it's basically just a coil and you should be able to measure it for continuity.
Of course this means accessing the solder side of the board so be real careful that it's been switched off for a while and the mains plug is pulled.
If it has died you should still be seeing something on-screen and hearing sound.
If the set is totally dead then I think the fault lies elsewhere.
Cheers
Rob
Old 9th September 2006, 05:54 AM   #6
poobah is offline poobah  United States
poobah's Avatar
That is an inductor or a transformer... for high freqs... like 100 K to 1 mHz. Most likely it is NOT your problem.
TV's are dangerous as hell... stay away from the picture tube and ANYTHING hooked to it.
Old 9th September 2006, 06:23 AM   #7
The TV has been unplug for over a couple of months so I'm guessing it should be reasonably safe.
The TV still did turn on but it was a black screen with a bit of a white squiggle down the bottom if I remember correctly. What kind of sound should I be hearing?
It test ok for continuity, assuming I was measuring the right points on the underside, I could unsolder it to double check.
Are these things normally suppose to be variable? the centre core is actually raised above the metal casing. Is there anyway to check what value is need?
If you click on the picture it should show it zoomed in a fair bit. If that's not clear enough I could take a better picture tomorrow when I have better light.
Old 9th September 2006, 06:41 AM   #8
poobah's Avatar
I have a sad story about a TV... too long to tell. Buy a new one.
My BEST advice.... really.
Read the forum rules... no TV here.
My short story:
I got divorced.
I had nothing.
I bought TV.
It worked for 8 Years.
It broke.
I fixed it.
It broke again.
I fixed again.
It broke again.
I fixed it good!
I left it in the street for the garbage man.
Old 9th September 2006, 06:52 AM   #9
Just normal program sound.
These things are specific to the set they're in so you would need to obtain the correct part number from a service manual and locate a supplier who carries parts for your make and model.
You could try posting here in the Television thread
http://70.84.232.2/~hcsdcom/phpbb2/
Quote your make and model and chassis number, if you can locate it, and the component reference. Somebody there may have a manual and be able to look up the part number for you.
Cheers
Rob
PS. I still don't think it's the problem.
Old 9th September 2006, 07:00 AM   #10
Sorry I didn't realise it was against the forum rules. You can close the thread if you want admin.
Thanks for all you help guys.
Closed Thread
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
Clear picture picture of KSS-273B eledora Digital Source 0 27th October 2007 01:10 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Page generated in 0.10918 seconds (78.32% PHP - 21.68% MySQL) with 11 queries
