Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th September 2006, 03:56 AM   #1
keantoken's Avatar
Default can't find good complementary transistors
I have had a problem with supposedly complementary transistors. It seems that many transistors that are "complementary" aren't really all that good twins. I need strongly complementary transistor pairs! I have seen a lot of 2N3904/2N3906 pairs but high-end circuits don't use such low-power transistors! Could someone list some good complementary pairs? I can't hope to achieve good amps if I don't know of any truly complementary transistors! Any help appreciated!
Old 8th September 2006, 05:10 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Your post is not clear or specific enough.You don't expect 2n3904/2n3906 to be high power they are small signal transistors.The reason you don't see them in high end circuits is because they are not low noise types.There are no truely complementary pnp/npn transistors because of semiconductor properties/physics.What you get is close/similar characterics,this is not a perfect world.What do you really need,small signal or high power output transistors (presumably bipolar type)?Check the solid state forum.
Old 8th September 2006, 11:21 PM   #3
keantoken's Avatar
I am needing low-noise and high-power, maybe 2-4A at 60V for output pairs. I have read a book about semiconductor design and I know that transistors can't always be made perfectly complementary bacause of different doping elements needed for P and N matierials. I have heard that GaAs transistors are good, low noise but I don't know about current and voltage handling capabilities. Yes, I need bipolar. Sorry for the utterly bewildering lack of specifics, I can do that sometimes
Old 9th September 2006, 12:26 AM   #4
I would suggest going to ON Semiconductor's website:
www.onsemi.com
and using their parametric search for bipolar transistors. You should be able to come up with something in your range of power, but I'm not too sure about noise (most low noise transistors are small signal and very low power).
Old 9th September 2006, 02:29 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Some Japanese names such as Toshiba does manufacture low noise BJTs with high voltage rating.
Old 9th September 2006, 03:25 AM   #6
originally by keantoken
For 1A and above it is assumed you would have taken care of noise .Now it's about voltage and current delivery. Motorola or now ON Semiconductor has an old favourite specifically designed for audio which is MJE15031/28 @8A, or BD240, TIP31/41. etc.
Old 10th September 2006, 08:52 PM   #7
keantoken's Avatar
I just tried the MJE15031/28 pair and they weren't similar enough. I have also tried the MJE15031/30 pair and they were better... I am building a symmetrical amplifier that uses more pnp's than npn's on one side and vice-versa. I think that the differences are being amplified... I guess my design needs strongly complementary transistors... From my amplifier design it might be obvious that I know barely anything about biasing transistors. I can bias a standard common-emitter, but I can't really understand how to bias Q3-Q6, but I think I am getting there. It probably isn't the best design but I don't think it's the worst either. At least it's a start, I think I might need another output pair if I were to design it to someone else's taste though. Although this circuit was posted for all to see and criticize, at lest help me to get it working! Here it is:
Old 10th September 2006, 09:21 PM   #8
Tim__x is offline Tim__x  Canada
Stop just throwing transistors together. Read those links I gave you a few threads ago. Learn how standard topologies work before creating your own. Try to analize a two stage LTP-VAS amplifier first, just three transistors, three resistors and one capacitor.
Old 10th September 2006, 09:28 PM   #9
Here's a (stripped down to the bare essentials) example.
P.S. R4 is the load i.e. the input of the next amplifier. Note how it goes from the output of the amplifier to ground.
Old 10th September 2006, 09:34 PM   #10
Tim_x,
You must be the guy who posted those links. That was a nice gesture; I think keantoken looked at them, but obviously, he didn't spend much time trying to understand them. keantoken may be smart enough to figure out how to bias transistors, but he clearly hasn't demonstrated it yet. keantoken, I would like to see you show a properly biased common emitter stage. Make it simple, one transistor with a current gain of 100, 3 resistors Rb, Rc, and Re with a couple of supplies; Vcc and Vbb. If he can't do this, he's lost.
Rick
Biggest Complementary Transistors EWorkshop1708 Solid State 31 13th June 2008 10:43 PM
High-Voltage 350-400V Complementary Transistors for VAS :needs info ? Workhorse Solid State 9 30th August 2006 02:37 AM
Complementary med pwr transistors? janneman Parts 22 16th June 2004 09:18 AM
complementary transistors needed sss Solid State 2 25th October 2003 02:20 PM
Page generated in 0.11860 seconds (81.70% PHP - 18.30% MySQL) with 11 queries
